Take out the battery and let it dry out for like a day or two........ if this doesnt work i dont know what else to tell ya cas its worked on my past phones
Please take note; once a phone drops into water or any liquid, first thing you need do is to remove the battery, get a phone screw driver, loose the phone and dry the phone board with bulb or any heat.
The essence is to dry the water totally from the board, because if it dries itself, the phone board will get rust and phone might not work properly again.
Back to your phone, I think the liquid as entered your screen and its not dry yet, that's why its white.
Put off the phone, remove the battery and leave the liquid to dry on the screen or put is near a very light heat and the liquid will gradually dry off.
you can take the battery and the back off the device and place in completely submerged in a bag of white rice and leave it in there for 1 to 2 days this will help absorb the moisture, this should fix it if the water did not damage the circut boards if the water damaged the circut boards then the device is fried
You can find the screen on ebay, i had the same problem. Bought one for $20, sprint wanted to charge $100..you can find on youtube how to replace it yourself. I did it, took 15mins and my phone came back to life!
The flex cable that connects the two pieces that make up the phone are worn out or disconnected inside. you need to open it up and check it out. Go to http://www.youtube.com/watch?v=hNaCfrqqnd0
It has something to do with a cable that connects from your keypad to the rest of the phone. If you bring this back to the place that you got it at, they should be able to get it fixed. I know I asked about it when I bought mine, and they said that they don't have the cables there yet, so they would have to send the phone away to get it fixed.
You should buy a new phone, 90 percent of the time the screen shorts out when it gets wet. These phones are terrible, i would take advantage of having to get a new phone and get something completely different.
