CLEANED PRINTHEAD. PAPER JAM ERROR,DOES NOT PICKUP FROM PAPER TRAY, GEARS GRINDING, CANT CLEAN OR TEST PRINT, PLEASE HELP,
Sir/Madam
MAKE SURE YOUR BROTHER MACHINE IS THE DEFAULT PRINTER
If the printer driver is not set as "default printer", you can not print. Make sure your Brother machine is set as default printer. If your brother machine is not set as default printer, set it as default printer.
DELETE ALL PRINTER JOBS
2 Click Print & Fax, Print & Scan or Printers & ScanMFC465CN-PAPER JAM- NONE IN MACH.CANT USE - 9e320b57-f073-4ece-af2d-e8c4e556e648.gif/9e320b57-f073-4ece-af2d-e8c4e556e648.gif" alt="9e320b57-f073-4ece-afMFC465CN-PAPER JAM- NONE IN MACH.CANT USE - 2916a062-c434-48a3-b727-9e6da281214b.gif
4.
For MMFC465CN-PAPER JAM- NONE IN MACH.CANT USE - 5f6280b5-327d-4545-bfbc-dc5d36c3ea81.gifoose the print job (1) and click Delete (2).
CHECK THE PRINTER STATUS
Choose brother machine's icon and click "Open Print Queue..." then check the printer status.
The Resume or Resume printer icon which is surrounded by red lines is displayed in printing when the printer is out of paper or MFC465CN-PAPER JAM- NONE IN MACH.CANT USE - 760770a6-be0c-417f-b603-2d0837d5ca0d.gifResume or Resume printer.
For Mac OS X 10.8 or later users
MFC465CN-PAPER JAM- NONE IN MACH.CANT USE - c5fb0dd7-b7a4-4c3a-8469-616fecb5b9f6.gifa6-be0c-417f-b603-2d0837d5ca0d.gif" alt="760770a6-be0c-417f-b603-2d0837d5ca0d.gif" class="h_mi" />
For Mac OS X 10.5 - 10.7 users
If you connect the brother printer via USB cable, the error message The printer is not connected or OffliMFC465CN-PAPER JAM- NONE IN MACH.CANT USE - 4f45bd04-acd9-4801-babf-0c16abce6d97.gif> when the USB cable is disconnected or the brother printer is turned off. Connect the USB cable and turn the brother macMFC465CN-PAPER JAM- NONE IN MACH.CANT USE - 0e5d4f41-7114-49ca-9d01-35623f1dd09f.gif8 or later users
If the other error message is displayed on Print Queue, check if the LCD display or LED indication of your Brother machine MFC465CN-PAPER JAM- NONE IN MACH.CANT USE - 935a5a19-5cf8-4f57-9e64-5039c7fa0d04.gifs displayed, go to the Troubleshooting section and find a solution.
REGISTER THE PRINTER ICON AGAIN
In spite of if you click [+] button, the brother machine is not displayed, then the brother machine is not recognized.
If you use the printer via USB connection, reconnect the USB cable or restart the Macintosh or your brother machine.
For Mac OS X 10.4 users
I Suggest You Go To Official Brother Printer Website For Brother Printer Troubleshoot:
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/002600/000046/faq002646_001.html?reg=us&c=us&lang=en&prod=mfc5860cn_all
Or
If You still having Problem Then Follow Us For Brother Printer Support
SOURCE: Brother MFC-620CN print head clogged
Open up amd release blue stay at bottom by pressing edges inward and pulling slightly forward. Remove the 4 screws, 2 small plastic covers and the earth screw. Pull out the ribbon connector near the USB plug. Unplug the 2 white and one red connectors, noting how the cables fit in. Fully open the lid and pop the scanner part off. Remove all the ink cartridges. Now using a flat screwdriver unclip the top of the base all the way round and lift off. The print head is now accessible. Rotate the white paper feed cogs to release the print head. Slide it all the way to the right and remove it by tilting the back edge upwards. You mow have access to the print head!!!!
SOURCE: Brother MFC-9420CN Paper Jam Error message w/ loud grinding noiz
please try this
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
SOURCE: My MFC8460N Brother won't print. It makes this
Gears on the tray is broken, or the gears that lift the tray. (thus the clicking noise). And the no paper is due to the actuators underneath not being activated because of the non lift.
Jams in tray 2
Table 7-10 Causes of tray 2 jams
Cause Solution
The feed or separation rollers are dirty, worn, or damaged. Clean the rollers. If they are dirty after cleaning, or if they are
worn or damaged, replace the rollers.
The pickup roller is worn or damaged. Replace the pickup roller.
The tray 2 paper pickup assembly drive gears are damaged
or the assembly is defective.
Check the drive gears in the paper pickup drive assembly.
Replace the pickup drive assembly if the gears are
damaged. See Paper-pickup drive assembly.
The tray 2 pickup solenoid (SL101) is damaged. 1 Disconnect the connector for the tray pickup solenoid
from the dc controller PCA (location J92).
2 Measure the resistance between the cable connectors.
3 If the measured resistance is not approximately
160 ohms for the HP LaserJet 4200/4300, or 110 ohms
for the HP LaserJet 4250/4350, replace the tray 2
pickup solenoid.
The tray 2 lifter-drive assembly or the stack position
sensor (PS107) is defective.
Replace the lifter-drive assembly. See Tray 2 lifter-drive
assembly and/or Printer switches and sensors.
The dc controller PCA is defective. Replace the dc controller PCA. See Dc controller PCA.
Dirty, worn, or deformed pick-up roller, cassette separation
roller, and cassette feed roller.
Clean the rollers if they are dirty. Replace any worn or
deformed rollers. The cassette separation roller and the
cassette feed rollare are to be replaced together.
Damaged gears in the cassette pick-up drive unit. Move the gears in the cassette pick up drive unit. If the
gears are not rotating correctly, or are damaged or worn,
replace the cassette pick-up drive unit.
