Sounds like you need to replace the hot rod. Contact Traeger on their website at www.traegergrills.com for parts and instructions.
SOURCE: The pellet auger on my traeger doesn't feed pellets
Call Treager direct
They have a great customer service dept and if you have an issue with a motor or control board they are really good about sending replacements
800-372-3437
If this helps please leave a comment
SOURCE: Our traeger smoker is smoking but is not emitting
You need to replace the element inside the smoker!
SOURCE: Traeger smoker - the flame ignites but the fan stopped working
Use White Lithium Grease from a spray can. Blow into the shaft side of bearing.
SOURCE: Traeger Grill has inconsistent smoke temperature
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
SOURCE: Err message on my Traeger
I had the same problem; I talked to Traeger talked to their rep and he walked me through fixing the problem. There are two wires leading from the temperature probe, these lead back to the thermostat digital controller. With the unit unplugged, unscrew the two screws holding the temperature controller in place. Slowly and carefully pull out, and check that both wires are running into the controller. If either is disconnected, strip a little more wire off the loosened wire, put back in hole and tighten the wire back down. That was the trick for my grill. Reassemble and reconnect power and test it out.
