Video Cameras Logo
Posted on Dec 19, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Blue screen on TRV260 playback
I have Sony Handycam TRV 260. Last week it started giving message about dirty head. So I tried to clean the video head using nail polish remover solution and a ear-bud. After this, now the handycam doesn't play at all. When I try to playback, it just shows blank blue screen. Can anybody help? Thanks. /Hemant
Tony Parsons
Level 3:
  • Sony Master 6,405 Answers
  • Posted on Dec 20, 2017
Tony Parsons
Sony Master
Level 3:
Answers
6405
Questions
Helped
1650100
Points
20272
Congratulations !!! This is probably the worst attempt at self-solving a problem I have found in over fifty years. I am sure that somewhere there must be an award for you.
Clive
Level 3:
  • Sony Master 882 Answers
Clive
Sony Master
Level 3:
Answers
882
Questions
30
Helped
212468
Points
3292
TRV260 nail-polish head attack:
eek.
Acetone is a powerful solvent capable of dissolving plastic parts, plastic gears, housing and insulation.
Besides that, it leaves a residue of microscopic crystals which have probably contaminated the highly-polished metal head drum.
Not to mention gumming up the bushes and bearings.
With your next camera, rather use a head-cleaner DV-tape.
1 Related Answer
ripleymojica
Mando Mojica
  • 643 Answers
  • Posted on Jun 02, 2009
SOURCE: Blue screen on TRV 260 playback
tape head is damaged. sometimes the internals unwind on the head if not done properly.
MY SONY CAMERA DCR TRV 260 IS NOT RECOGNISED BY PC WHEN CONNECTED WITH USB CABLE.NO ICON COMES IN MY COMPUTER.HOW CAN I TRANSFER MY VIDEO TO PC.
Use a firewire cab le to connect to the computer. Then open Windows Movie Maker to capture. With Digital-8 you may have to start the camera manually. eg. push the play button on the camera
My computer will not acknowledge my Sony Handy Cam is connected. DCR TRV-260. I need to down load the video from the sony.
I found out that Vista doesn't work with older Sony camcorders and there is no updates for it. I have to use my old computer with xp and the program that came with it.
Not sure if this will help you.
TRV-350 playback problem
Sounds like dirty heads. Get a head-cleaning tape and run that.
Sony vx2100...blue playback screen
in either case the head condition is bad.. pls inspect the tips on the head whether it is not damaged in the cleaning.inspect the drum hours also..
Won't playback
Use good quality video head cleaning cassette because video head seems dirty/ clogged. If it doesnt solve the problem, video head need to be replaced.
2answers
Sony TRV 460
Hello dears,
Both camcoders DCR-TRV460 & DCR-TRV260 has defect in CCD Imager IC. Please contact nearest Sony repair shop for replacement of this part.
1helpful
2answers
Cannot playback hi8 ccd trv107e pal
Dirty video head! Playback newly opened blank tape for five minutes, after that eject, reinsert, playback then eject again five times, these will serve as your video head cleaner, never use "video head cleaning cassette tape" for it will only damage your camera. Most camera has built in video head cleaner installed inside and activates only when you insert, initial play/rec, and ejects a tape. If the problem is still there you need pro fix then.[:0)
Playback
if the camera is going on in the play mode and you are getting a blue screen with play indicator it is mostly due to dirty head. what have you used for cleaning the head. take the help of repairer for cleaning as he will do so after opening the cover. if that doesent solves the problem then get the video head checked for any damages such as broken tips.
3answers
Camcorder
if all the indicators i.e. battery condition, play mark, counter, etc are visible on the screen then it can be a simple problem of dirty video head. try using a head cleaning cassette or do the head cleaning manually, Open the cover by removing three screws on the right hand side next to the viewfinder. Slide it little towards front and pick it up. The video head will be visible.
Top Sony Video Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
