Question about Minolta Di3510 All-In-One Laser Printer
How to add konica minolta bizhub Di3510 on windows xp
Adding konica minolta Di3510 on windows xp
  • Minolta Master
  • 6,862 Answers
Down load the driver from konicaminolta or use the disk with the copier.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Jan 10, 2015
6ya staff
SOURCE:
mochicas
  • 26 Answers
SOURCE: Driver utility of Konika Minolta Bizhub 162
Use the bizhub 180 same family
driver
Posted on Feb 21, 2009
herminio_hal
Herminio Halili, Jr.
  • 210 Answers
SOURCE: Bizhub Konica Minolta - Error Code C1183
First check the alignment front and rear of the finisher, check the finisher exit guide rollers if the paper is exiting properly, open both rear and the front cover and check the lower gears attach is the up/down drive belt. that lower gear one might be broken by the pin slot.
Posted on Jul 09, 2009
SOURCE: ERROR C0910 KONICA MINOLTA BIZHUB DI 2010
2nd Drawer Lift-Up Motor Failure - The Lift-Up Sensor is not unblocked even after the set period of time has elapsed after the paper liftup operation for the drawer has begun.
Reset your Toners and Imaging units for Bizhub and CF series.
http://www.chipreset.eu
Posted on Nov 27, 2009
firecontrol7
Norman J Weimar Jr
  • 6862 Answers
SOURCE: konica minolta bizhub 350 error code c5352
Cooling Fan fault. To clear open and closer the front door.
Posted on Apr 04, 2010
wheatlandsvc
Edwin Martens
  • 1110 Answers
SOURCE: kONICA MINOLTA BIZHUB 750 SHOWING C3803 ERROR
You have a problem with the fusing unit. This is the assembly that gets hot and "fuses" the toner onto your paper. This error code means that the fusing unit did not warm up properly. You will need to have a service company come out to diagnose and repair the problem then reset this code as service mode entry is required in order to reset. It could be as simple as cleaning the thermistor, replacing the thermistor, thermal fuse etc. I would estimate the cost at around $200.00.
Here is the section from the service manual that deals with this code:
Thermistor /1 (TH1) detects a low
temperature when a specified
period of time elapses after the
fusing heater lamp is turned ON
for the fusing ON control.
Posted on Jun 09, 2010
Konica minolta dialta di3510
The pass code for the admin mode on the di3510 should be 00000000 (8 zerros ) OR Elevation drive motor failure for the finisher /service manual
Aug 28, 2012 | Minolta Di3010 Copier
Konica Minolta Di3510 All-In-One Laser Printer - Duplex / Booklet button cant edit
Check user setting tab 2/6 for duplex default
Mar 18, 2011 | Minolta Di3510 All-In-One Laser Printer
Minolta Di3510 All-In-One Laser Printer Logo
62 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ed
Ed
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
