How to reset the bios in this model? I notice this model has a small port near the memory slots I'm hoping doesn't require a special cable...
SOURCE: Toshiba satellite A100 slot 2 doesn´t work. A
Is memory matched (DDR2 667)
Have you put original mem in slot 2
Download / install CPU-Z with both modules in and run program to see if it shows.
If all above is correct may be damaged mobo.
This is for your laptop from vendors site.
Memory5
• Configured with 512MB DDR2 SDRAM (1 slot occupied and 1 available)
• 512MB(min)/2048MB (max), 2 memory slots using 256MB, 512MB or 1024MB PC4200 DDR2 533MHz SDRAM.
SOURCE: Unable to use my web
you are most likely missing the driver for your webcam
heres a link to the webcam driver:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=2592471&rpn=PSLU0U&modelFilter=L505-ES5011&selCategory=2756709&selFamily=1073768663
SOURCE: I have an Toshiba Satellite L505 Es5018 I forgot
You can't - it needs to go back to Toshiba for reset.
SOURCE: I have a Toshiba Satellite L505-S5990. I've
1. Turn the laptop up side down.
2. Remove the plates one at a time till you find a button cell about3/4 inches wide.
3. Remove this button cell for a minute or so.
4. Replace the button cell.
5. Close the plate.
6. Start using the laptop.
SOURCE: where is the jumper at on a toshiba satellite l505 s5990 for bios rest
Try removing the coin cell battery from the mother board for about 30 minutes. This resets the BIOS on a lot of laptops.
