SOURCE: i have a viper alarm with remote start the remote
the alarm is in valet mode .open a door press lock unlock lock on the remote and it should take it out of valet mode
SOURCE: Hello. My Viper 5701 suddenly
You should also be receiving an error message. If the parking lights flash six times, it relates to the hood shutdown wire(-) or the brake shutdown wire(+). If the parking lights flash seven times, it relates to the neutral safety shutdown. Check the toggle switch under the dash and flip it to the opposite position.
SOURCE: Just bought a`used truck that came with a Viper
That remote can work with both a security system, and a combo unit security/starter.
Best bet is to take the vehicle and remote to your local Viper dealer and they can look the car over and tell you what was installed and help you learn how to use it.
SOURCE: I think I messed up
If the led is solid blue when the key is out of the ignition that means your in valet mode. Which would disable the alarm, but not the starter.
Simply turn key to IGN position then back to OFF.Push the valet button which is on the antenna next to the led and the led should turn off.Close door on vehicle and lock vehicle.Siren should now chirp.
Cheers!!
