There is no update for the DMC-LZ2 available If Panasonic has new firmware for any camera, it will contact all registered owners and tell where and how to get and install the update.
Be aware, you only can update a correct working camera. There is no way to update a camera that does not function for 100%
1. Turn on the power of the printer. Check that the printer is online.
2. Run the file setup.exe in the FirmUpdate folder in the CD-ROM. [GARO Firmware Update Tool] will be installed.
3. Run [GARO Firmware Update Tool] from Programs in the Start menu.
4. By following the instructions, update the firmware version.
2. Select the OS89 folder in the FirmUpdate folder in the CD-ROM, and run [GARO FirmUpdate]. [GARO Firmware Update Tool] will be installed.
3. Run [GARO Firmware Update Tool] from [Applications] - [GARO Firmware Update Tool] folder.
2. Select the OSX folder in the FirmUpdate folder in the CD-ROM, and run [GARO FirmUpdate].
Precautions when updating the firmware version
- Use [GARO Firmware Update Tool] after checking that the printer is online.
- Do not turn off the power of the printer while firmware data is being transferred.
- If the printer?s firmware is already the most recent version, the Status of the target printer will be displayed as ?Update Finished? when using [GARO Firmware Update Tool].
Techbelkin
