Question about Biostar P4M800 Pro-M7 (P4M8PROM7) Motherboard
My biostar P4M800 Pro-M7 only shows 1gig of ram, but i have 2gig... Wat could be the problem?
    President:
  • 1,185 Answers
Are both chips identical ? if so
Take out the ram and replace it one stick at a time in the socket 0 or 1
If both sets of Ram work then check your instruction book on the motherboard and see what is the maximum ram it will take .
Get a copy of Memtest86+ from www.memtest.org
and run it on both chips , that will show if there is any errors on them.
Posted on Jun 01, 2009
    President:
  • 1,901 Answers
Are you certain they are both the same kind of RAM, that is the correct type? (DDR2 PCC-8500/6400/5300 Non-ECC)
Are you using 2 1GB modules? Are they seated securely?
If you are using 2 modules, try them 1 at a time to see if they both work individually. If one works and the other does not, either it is a bad module or the wrong type.
    Habit-Forming:
  • 75 Answers
You may need to update the bios to support 2 Gigs of ram,or one stick of ram ma by no good.You can try the sticks of memory in another PC that supports the type to test them out.
6ya staff
SOURCE:
I need vga driver of p4m800 pro-m7
Hello the homepage is here:
http://www.biostar.com.tw/app/en/mb/introduction.php?S_ID=94#dl
But the driver for win 7 is not there.
It will not help to download the xp driver
My advise is to buy a graphic card that supports win 7
The mainboard have an AGP 8X Slot for extenal graphic card
If you are in doubt adding a graphic card
let a expert do it for you.
Good luck
Oct 30, 2012 | Biostar P4M800 Pro-M7 Socket 775 mATX MB...
Get sound drivers
Hello DJ Shenon!
Biostar has all the drivers for your P4M800 Pro-M7 motherboard available for download on their website. The link for your motherboard is P4M800 Pro-M7
Nov 22, 2010 | Biostar P4M800 Pro-M7 Socket 775 mATX MB...
Replacing memory on the P4M800-M7 A motherboard
No. Just make sure that you two RAM modules have the same specifications (speed, clock).
If you don't know about that, then simply insert both RAM modules and start your computer. If Windows loads, then right click on MyComputer and go to properties. If it shows 1.5GB then you are OK.
If the computer fails to start or you hear multiple beeps it means that they are incompatible.
Replace the 512 module and insert the new one and try again.
Always remember to turn off the power and unplug the cable from the power supply before replacing RAM modules.
Jan 28, 2010 | Biostar P4M800 Pro-M7 Socket 775 mATX MB...
DDR2's only showing half installed RAM
IF THE SYSTEM SAYS YOU HAVE 1GB RAM THAN YOU HAVE 1 GIG OF RAM, EVEN THOU SOMEONE TOLD YOU YOU HAD 2-512MG=1GB.
HERE IS HOW I SEE WHAT YOU ARE SAYING YOU HAVE 2-DDR-2 1 GIG STICKS THAT MEAN IF 1 IS INSTALLED THAN YOU HAVE 1 GB AND IF YOU COULD GET 2 STICKS WORKING TOGETHER THAN YOU WOULD HAVE 2GB RAM.
1 CHIP SET = 1GB RAM
2 CHIP SET = 2GB RAM
YOU MOTHERBOARD MAY NOT ALLOW THAT MUCH RAM, OR WHAT I MEAN THE BIOS MAKE UP THE AMOUNT OF RAM.
TO RULE OUT ANY BAD CHIP SETS OR GOOD RAM OR BAD RAM.
TAKE THE PEACE OF RAM THAT IS WORKING OUT AND REPLACE IT WITH THE OTHER PEACE AND SEE IF IT WILL RUN.
IF IT WORKS THAN LEAVE THAT ONE IN PLACE AND INSTALL THE SECOND PEACE IN THE SECOND SLOT.
IF BOTH CHIP SET ARE GOOD THAN BOTH SHOULD WORK OKAY TOGETHER.
IF THERE IS A PROBLEM, IT MAYBE SOME DUST IN THE MEMORY LOTS
OR THE SLOT MAYBE DAMAGED.
OR
THE CHIP DESIGN LAYOUT MAYBE THE OPPOSITE SIDE, THIS MAY MEANS THE CHIPS MAY FACE EACH OTHER, OR FACE OUTWARD FROM EACH OTHER.
ROD
Mar 14, 2009 | EliteGroup P4M800-M7 Motherboard
Elite group P4M800-M7 Can i use 2GB 667 / 800 ddr2????
I have p4m800-m7 also and i cant seem to get both sticks to work.....I still have only 1 gig with both sticks i have 2 DDR-2 1Gig sticks PC2-5300 533 mhz
Mar 12, 2009 | EliteGroup P4M800-M7 Motherboard
Motherboard
It doesn't matter the version either. Biostar has removed this manual. I foun it on a ftp site & could not find that jumper any where.
Mar 16, 2008 | Biostar P4M800 Pro-M7 Socket 775 mATX MB...
Biostar P4M800 Pro-M7 (P4M8PROM7) Motherboard Logo
820 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
Ekse
Thomas F. Schneider
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
