its a problem with the fuser unit ,its overheating .two ways to solve it first check if the sticker paper is supported by your printer ,2nd you may need to replace the fuser unit
In my printer paper side is a piece of wire and I cannot take it out. so the printer say erore as is a paper jam problem. Haw can I open this zone to take out the wire?
why print velvet paper? the problem is the velvet would be too thick and it would jam the print heads because when they run over the paper it would pull the velvet and it would get jammed i don`t think you should print velvet
the eror is probably caused by dust or paper slivers somewhere or a open door or the paper trat not being in right. Open everythign up look for dust and stuff then makre sure it is all closed and the tray in in right. It should then reset and the error goes out.
Usually this is from dust on sensors or a tiny sliver or paper jammed somewhere. Can be quite annoying to find and get rid of.
