I have bought a diesel 7071 watch and the instruction manual seems to apply to every watch but the one I bought. I have also tried the instructions currently on this site for another type of diesel watch but no luck there either. Can anyone help? Sou brasileiro. Acabei de adquirir o relógio e o manual não me ajuda em nada! Não consigo colocar a hora atual, não consigo colocar a data nem o dia da semana. Alguém cnseguiria colocar passo a passo de como fazer? Não consigo identificar os botões A, B, C e D no meu relógio de acordo com o manual. Acredito que o A seja o inferior esquerdo, e assim seguindo a ordem, estou certo? Obrigado desde já pela ajuda que qualque rum possa me dar! "I am Brazilian. I just purchased the clock and the manual does not help me at all! I can not put the current time, I can not put the date or the day of the week. Someone cnseguiria place step by step on how to do? I can not identify the buttons A, B, C and D on my clock according to the manual. I believe that is the bottom left, and thus in the order, am I right? Thanks already for any help they can give me rum!"
SOURCE: Diesel DZ7069 watch - how do I set the correct date/time?
ok ,here it is .
Instructions To Set The Time On The Diesel DZ7071 Watch
Ok the first and most important thing to know about this watch is that it has an unusual timezone function (unusual to me at least). This allows the watch to display two different times. Time 1 (or T1) is the primary time (the time of the place where you spend most of your time!). The time can only be adjusted whilst the watch is in the T1 mode (T1 should be displayed in the bottom left corner of the screen). Holding down the top right button for one or two seconds will temporarily replace the current T1 time with the T2 time. Holding down this same button for several seconds will toggle the current time mode to T2 and the watch will continue to function in the second time zone until you toggle it back to T1.
The second most important thing to know is that you can only set the time whilst in the T1 mode. When in T1 mode hold down the top left button until the watch enters the settings menu (it should say "Light" at the top of the screen) now use the bottom left button to toggle through the settings menu until you get to the time settings. I think this part of the process if sufficiently straight forward so I'm not going to go into more details here, all I'll add is that once you have the watch set to the desired time mode 12h/24h time and date you just need to press the top left button to save the settings and return to the main time screen.
To set a secondary timezone time you have to first toggle the watch to the secondary time zone mode (hold the top right button for several seconds and the T1 indicator should change to T2 (and the watch will now be displaying the time that is currently set for the secondary timezone). This time is based on the primary time by simply telling the watch a number of whole hours ahead or behind the primary time. To adjust this hold down the top left button for several seconds, the watch will then say "offset" now use the buttons on the right to add or subtract hours from the primary time. Once set press the top left button again to return to the main time screen. Finally hold down the top right button for several seconds once more to return the watch to the T1 mode.
SOURCE: I cannot set the digital time on diesel watch DZ7101
First look for the set button then press it ,a long press and If it is blinking that's the time you to select the hour ,the minutes,the day/date,the alarms and the special features of your watch.The right button the up and down or for scrolling.Try all of this so your time will set.
Hope it may help you;
Regards;
VOTIT DON'T FORGET TO RATE
SOURCE: looking for an instruction manual for a diesel
Hi, I just picked up this same watch from Ebay and it came with a standard diesel operating instruction book. I haven't read it yet, but if you want me to look anything up for you, please ask. As it turned out my watch need new batteries when it arrived, so the jeweller who fitted the batteries set all the functions for me.
Thanks,
Paul
