I have a Panasonic MC-V9647 canister vacuum cleaner. The cord is hung-up in the take-up real and will neither retract or come out. How to access the take-up spool? How do I take the cover off the rear portion of the vacuum to access the spool? I cannot find any screws.
SOURCE: Where are screws located that access main motor
If the model is the same as pictured, the screws should be visible.
If the model is older like I think it is, the screws are going to be a tad tough to get to, but not impossible.
First you will need to take the bag door off. Open it like you would to change the bag and then push the bag door back farther so that the hinges "pop" out. Generally how i do it is put it on the counter, with the bag facing you, open as far as you can, grab the top portion of the bag door and push it back quickly.
Now, when the bag door is off, with a flat screw driver, the colored housing above the gray bumper will come off. insert the flat screwdriver in there and pry it open a touch. do that to the other side as well. Once both sides are open, you want to slide the screwdriver towards the back of the unit and gently pry the back off.
under there you will find 2 screws (if you need to go that far at this point) and you can remove the back of the unit easily.
Good luck,
Mark
