SOURCE: my delphi xm is frozen
My radio was stuck on "scanning media" and the regular reset (volume up and Mode) did not work.
Nothing that I did, fixed it...
I called Delphi and they said...
(1) Put radio in it's cradle, press Volume UP/Mode buttons for 3 seconds until it resets.
(2)Then when the "scanning media" message appears press up arrow, down arrow, up arrow.
My delphi screen unlocked. I LOST everything that I had recorded, but that was fine with me.
I had to update the firmware and everything is working fine.
Losing all my recorded songs was much better than having to send in my radio!
Hopefully this will work for you!
Delphi was extremely helpful and very nice so don't be afraid to call them if this doesn't work!
SOURCE: lost the user manual
go to google.com and type skyfi2 xm radio manual. you will find the manual there as a .pdf file.
Hold the up volume button and the mode button at the same time. I have to do it almost every day. This is only a problem when using the car kit. No problem at all when using with portable kit or home kit.
SOURCE: New Delphi installation over older delphi car kit
Just installed the xpress RC in my Durango, replacing my SKYFi2. Both units are Delphi (all of the newer xpress RC's are made by Audiovox now, but Amazon sent me the Delphi made unit). Everything swapped out with the exception of the 12dc power cord. Had to use the one included in the new unit, plug size that goes in the new cradle for the RC is different. In the new unit I did get two "user guides" in Spanish and none in English (I wish America would adopt one friggin standard language. English) but other than that it was quick and painless.
SOURCE: delphi skyfi2 Xm Radio Receiver car connection
Yes, you can buy an FM Direct adapter that will allow you to transmit directly to your car FM tuner, but if you have an older SkyFi2, the Fm transmitter is so strong, you can sit the radio on the floor and tune your car radio to your preset XM channel, like 107.1 FM and it will work great. Go into "Menu" and pick a channel that's not used locally.
