Dell Inspiron 1545 Notebook Logo
A
Anonymous Posted on Jul 08, 2017
While typing, the keys change to different letters
Usually on email, as that is mostly what I use this computer for... I'll be typing and suddenly the keys I'm hitting are typing out diffferent letters. I haven't been able to figure out what I'm touching if anything nor made any sense of how it is changing, a mirror of the keyboard or whatnot... I have to shut down the email and reopen it to reset. This is happening more frequently, 5 times yesterday alone. Thank you, Barbara
bobwin
Level 2:
Problem Solver:
  • Expert 58 Answers
  • Posted on Jul 08, 2017
bobwin
Expert
Level 2:
Problem Solver:
Answers
58
Questions
0
Helped
17562
Points
136
Is your shift key stuck in the down position? Try pressing it a few times to release the key.
5 Related Answers
Anonymous
  • 2028 Answers
  • Posted on Jul 15, 2008
SOURCE: my laptop keeps making beeping sounds when i type.HELP!!!
Do a system restore to a point previous to the power failure shut down. It sounds like the abrupt shut down glitched the system.
Anonymous
  • 32281 Answers
  • Posted on Feb 03, 2009
SOURCE: Typing delay
You can change the repeat delay times on your keyboard.
Click on the Control Panel then Keyboard icon. In the Speed tab you can change the Repeat delay and the Repeat rate settings to suit your requirements..
Anonymous
  • 828 Answers
  • Posted on Jun 17, 2009
SOURCE: Cursor jumps around screen when typing
your dell laptop are supposed to have a program on touchpad, if you dont have that in your system then the touchpad is jumping
Anonymous
  • Posted on Jul 10, 2009
SOURCE: keyboard stuck on fn
I found this on another site, and it worked on my Vostro 1510:
Try pressing shift + numlock (Scrolllock in blue) to toggle the Fn feature.
Normal numlock comes on, so press it again by itself to turn that off.
Anonymous
  • 17 Answers
  • Posted on Oct 06, 2009
SOURCE: My touch pad is SUPER sensitive, when I type...
From Dell:
Customizing the Touch PadYou can use the Mouse Properties window to disable the touch pad or adjust the touch pad settings.
  1. Click Start keyboar4.jpg , and then click Control Panel.
  2. Click Hardware and Sound.
  3. Click Keyboard.
  4. In the Mouse Properties window:
    • Click the Device Select tab to disable the touch pad.
    • Click the Touch Pad tab to adjust touch pad settings.
  5. Click OK to save the settings and close the window.
I have an older lg.wen I txt, I can't get 1 letter at a time
Besides the fact that you should get rid of that ancient device as they make life difficult lol you have to change the settings from t9.
When you are in the texting area you only have to hit the right key to change from t9 to Alphabet (not sure it's the exact spelling for t9 but one of the keys (usually bottom left or top left corner will allow you to type normal or to guess words by what you type, some of which can be confusing.)
for the letter e you have to push the 2 key 3 times I believe, if you keep pressing each key you will see different letters, numbers and symbols, perhaps a Users manual is available online (can google it, is available to tell you how to change the texting type.
Dunno this helps but it's so old I cant recall exact details but that's the gist of it.
Nov 22, 2017 • Cell Phones
How do I change font size in my e-mail - make letters smaller
Depends which E-mail process you are going through, but it is usually the letter A a to show size difference or a drop-down menu for type of font and a number.
2helpful
How do I turn off key board shortcuts?
Check your keyboard...
Is the Alt or Ctrl buttons stuck or pressed down?
If none of the above then it sounds like you need a new keyboard.
You'll be glad to hear they are quite cheap to buy and a professional should not charge a lot to replace it if you have the replacement part.
Wrong letters display when I type
Hi Check "Control Panel" > "Regional and Language Options" > "Keyboards and Languages" > "Change Keyboards". This brings up the "Text Services and Input Languages" dialog box in Vista (XP may be a slightly different path). This box will display (in the "Installed services" section) how many keyboard layouts are installed on your computer. If have more than just the "US" keyboard installed, there exists certain keyboard combinations with the "Ctrl" key that will automatically switch your keyboard layout from the default US to another one that is installed
Backspace key frozen
You'll have to take the computer to a service center to have the keyboard replaced.
1helpful
On my laptop in green are symbols and numbers, for example letter L has a green 3, when I try to type a word with the letter L a 3 appears, how do I change this? At the moment I have my old keyboard...
if you press the L key and the number 3 comes up. you likely have the num lock on.
is different for every computer but usually you can deactivate the num lock by pressing 2 keys at the same time.
the fist key is usually the key labeled (Fn) and the other key is usually a function key (the ones with F an a number), the way to find which is the other key is to look at the keyboard and try to find one that has a simble that looks like a tiny numerical key-pad
press both keys and a light that signals that the num lock is on should go off. at that point you should have your l and any other letters again typeable.
good luck
1helpful
Wheelwriter 3 Selector Assembly
The selection motor bearings just right of the print solenoid get dry a little WD40 on the front and rear bearings usually takes care or this.
DickyO
There seems to be an issue with the keys and buttons on the sidekick. When i hit the volume, it scrolls down or up. When I hit certain keys, it types a number of different letters/numbers. What might be...
Some fixes:
1. Change your keypad and see if it works. 2. If you have changed the panel recently it is the problem you need to fix it in exact position or you need to buy original panel for your mobile. Duplicates ll damage your key bed.
Rate me!!
Aug 17, 2009 • Cell Phones
Typing Email
try updating the java programme and your macromedia flash software, this usualy solves the problem in most cases, if you are using AOL and its software then there no real solution appart from removing the AOL software and accessing emails through your ISP's main servers.
hope this helps :)
2answers
Different keys display different digits or letters
better u just restore ur Operating system if ur using winxp take start-program-accessories -system tools-system restore then select restore my computer earlier time then click next and select the date before this problem found then it automatically restarting
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
