SOURCE: insignia video 2gb mp3 player wont go to menu
check on the setting display you might have it one 1hr shut off..you can easily switch it to off for then your mp3 won't shut off..
SOURCE: Insignia Mp3 player frozen
If you hold the power button for 20 seconds it will shut off. I had the similar problem where I unplugged my Insignia NS4V17B frozed on the bluetooth initializing screen. I turned it off then back on and it is now working fine.
SOURCE: insignia 4gb / video mp3 player
You'll need to erase the internal and external memory, then re-add all your files.
You can use Windows Explorer to transfer files to your insignia sport player. First, in the settings on your player, go to Settings, USB Mode, Connection Type and select File & Folder. Then, plug your player in to your USB cable. Windows XP should automatically find your player and make a new drive letter in Windows Explorer. Simply drag and drop your files from your c drive to the new drive for your player. You'll notice that when you delete the files on your new drive for your player that it doesnt remove them from your player. You'll need to use your player (settings, system, erase internal) to erase internal (and external), but after that when you add new files, they will be added to the player when it does the profiling after you disconnect the USB cable. [email protected]
SOURCE: screen frozen cannot turn player on or off
mine just froze right now so i held the power off button for like 30 seconds and it restarted without a problem try it
SOURCE: I have a Insignia CE1177 that is frozen.
there's a little rubber cover on the back just above the word insignia. use something sharp to pry it off. remove the small phillips head screw. grab the tabs on the sides and pull the back off. the two wires of the battery are connected to a small plug. unplug the battery and then plug back in. this cuts the power and acts as a reset. should solve the freeze problem
