What kind of switching options do you want? there are many ways to skin a cat but there are more ways than that to wire a guitar.. Visit the ibanez website for wiring diagrams if it is something simple you want. for more customised switching options,you should contact the pickup brand's customer care...for example,when i bought Dimarzios for my Ibanez,i emailed dimarzio and they replied within 24 hours with a pic of the correct wiring.
The power is regulated by an internal sensor inside the car, this should be close to the vents, you need to check the compressor first, because that is the main regulator if you bypass the regulaors and power it directly you will not find the problems.
Ok
where is connected the relay there 2 terminals 85 to 86 one is positive
and the other has to be negative when the horn push the SWICHT if when
you give negative fails to push these terminals the problem is in the
SWICHT, brush or turntable. All this is on the steering wheel hub
The
SWICHT is one but you must be sure that is the bad SWICHT that could be
the motor of the window you have to check this by measuring the voltage
at the terminal entering the engine
