RCA 25202RE3 Corded Phone Logo
A
Anonymous Posted on Jan 21, 2014
Ignore a call - RCA 25202RE3 Corded Phone
Bosch silenceplus 50dBA won't start
After 3 seconds of reset (start), turn the dishwasher off, wait a few secconds, turn it on, and use the arrows to select the washing mode (try Auto, perhaps) and see if this solves your problem.
Apr 12, 2012 • Dishwashers
I cant receive mms
The phone has a 4-way directional 'Navi' key and 2 soft keys on either side of this and 4 additional soft keys either side of the keypad. The Navi key can also be pressed in to select options.
1. Select 'Menu' (press Navi Key).
2. Scroll to 'Settings' and select (press Navi key).
3. Scroll to 'Configuration' select (press Navi key).
4. Scroll to 'Personal configuration settings' and select (press Navi key).
5. Press 'Options' (left softkey) highlight 'Add new' select (press Navi key).
6. Highlight 'Multimedia msg.' and select (press Navi key).
7. Highlight 'Account Name' select (press Navi key), enter 'giffgaff MMS' then 'OK' (press Navi Key).
8. Highlight 'Server address' select (press Navi key), enter http://mmsc.mediamessaging.co.uk:8002' and 'OK' (press Navi Key).
9. Highlight 'Use preferred access point' and select (press Navi key), highlight 'No' and 'Select' (press Navi key).
10. Highlight 'Access point settings' and select (press Navi key).
11. Highlight 'Proxy' select (press Navi key), Highlight 'Enable' and select (press Navi key).
12. Highlight 'Proxy address' select (press Navi key), enter '193.113.200.195' and 'OK' (press Navi key).
13. Highlight 'Proxy port' select (press Navi key), enter '8080' and 'OK' (press Navi key).
14. Ignore 'Data bearer' as this is set at 'Packet data'.
15. Highlight 'Bearer settings' and select (press Navi key).
16. Highlight 'Packet data access point' select (press Navi key), enter 'giffgaff.com' and 'OK' (press Navi key).
17. Ignore 'Network type' as set at 'IPv4'.
18. Ignore 'Authentication type' as set at 'Normal'.
19. Highlight 'User name' select (press Navi key), enter 'giffgaff' and 'OK' (press Navi key).
20. Highlight 'Password' and select (press Navi key), enter 'password' then 'OK', verify password and again select 'OK' (press Navi Key).
21. Press 'Back' (right softkey) 6 times to get to the main menu.
22. Highlight 'Messaging' and select (press Navi key).
23. Scroll to 'Message settings' and select (press Navi key).
24. Highlight 'Multimedia msgs.' and select (press Navi key).
25. Ignore 'Delivery reports' as preset to 'No'.
26. Ignore 'Image size' as preset to '640x480'.
27. Ignore 'Default slide timing' as preset to '00:08'.
28. Ignore 'Allow multimedia reception' as preset to 'Yes'.
29. Ignore 'Incoming multimedia messages' as preset to 'Retrieve'.
30. Ignore 'Allow adverts' as preset to 'Yes'.
31. Highlight 'Configuration settings' and select (press Navi key).
32. Ignore 'Configuration' as this will change to 'Personal config.' with the next step.
33. Highlight 'Account' and select (press Navi key).
34. Highlight 'giffgaff MMS' and select (press Navi key).
35. Press the right softkey 5 times to get back to the standby screen.
The MMS settings are now complete.
2answers
How can i remove my ignore from someone else ignore list
If you can see what other person is seeing in his/her dream, then you can remove your name from other person's ignore list...... So simple huh?
I can't send or recieve instant message
Check your messenger preference setting > Go to ignore list and check if you chose the option "ignore whoever not in my contact list" change that to "ignore as list only" and save. Let me know the result, hope it will help.
Thanks and regards.
How to block person in yahoo
If you mean to put someone on ignore so that you no longer receive messages from them then thats not to difficult.
While logged into yahoo messenger:
1.Click on messenger located top left
2. Scroll down and choose preferences
3. Choose Ignore List. You can ignore anyone one not on your list or choose ignore only the people below. Click add, type in their yahoo id and you wont get messages from them again..
If you didnt mean ignore please let me know..
How can i block some one msg
You can block a person's message from getting to you permanently.
First copy the person's email id and Delete the person from your yahoo list
1. Click the "Messenger" menu in Yahoo! Messenger and select "Preferences."
2. Click the "Ignore List" category.
3. Select the option labeled "Ignore only the people below."
4. Click the "Add" button.
5. Enter the Yahoo ID of the contact you want to ignore.
6. Click the "Ignore" button.
7. Click "OK" at the bottom of the window.
This should permanently block the person from sending you message from the ID you added
Friend blocked me on face book. how can i undo that
I just undone an ignore friend application requests by going to the privacy settings - applications - click on settings (next to overview), down the bottom below "Ignored Application Inviters", is the users you had earlier ignored, then just click on remove.
Ignored friends gifts and requests how do I get
...once yoyu've ignored the friends gifts and requests, the are deleted for good.........you might want to go to the applications which your friends sent you gifts and download the applications.......good luck
Always experience "you can not ignor yourself"
This is because somebody exceeds the flood tolerance in the chat room (posting a lot of messages). Normally Yahoo would automatically ignore the user, but a bug exists that Yahoo thinks you're ignoring yourself (when you're really not). No workaround.
Top RCA Lands Phones Experts
k24674
SmartAviator
SmartAviator
Are you a RCA Lands Phone Expert? Answer questions, earn points and help others
