Nokia N97  Cell Phone Logo
Ana-Marija Prosan Posted on Jan 21, 2014
Charging port Hi! i believe my charging port has been disconnetded from main board due to lot of use. My question is can i replace only charging port without changing mainboard? And if i can, do i need any additional tool other than screwdrivers and of course a new port? Thanks a lot and sorry for bad english
WhealBusy
Level 1:
New Friend:
  • Contributor 32 Answers
  • Posted on Jan 21, 2014
WhealBusy
Contributor
Level 1:
New Friend:
Answers
32
Questions
0
Helped
7283
Points
56
You will need a new micro-USB port and some fine soldering skills. Unless you're a pro with a soldering iron and have the necessary tools, take it to one of those little mobile phone shacks you find at markets etc. They're usually run by Asian gentlemen and they can do all this kind of thing quite easily and cheaply. Have a go at it yourself, but you will probably need a lot of lights and magnifiers. Have fun!
2answers
Hitachi 49 LED TV Le49s508 Main Board not working
It could be the eprom but its a difficult part to replace without a lot of soldering experience, I would change the board. Measure the PSON or PWRON, or how ever they have it labeled to see if you have a voltage change there when the power button is pushed.
Will not charge the port in the kindle fire broke
Hello!
We repair these A LOT! The jack is unbalanced on the Main Board and is easily detached by normal wear and tear. Soldering the jack back on to the board is a little tricky but the real repair is getting the port sturdy to prevent the issue from re-occurring.
We do a full repair by removing the old solder on the board and the jack then reattach using flux and fresh solder. We also stabilize the port so it doesn't happen again.
You can send it from anywhere in the US and we'll repair it for $39.95 which includes return shipping. I strongly recommend replacing the micro usb / charging port for an additional 9.95
www rockhoptec com
please call or email with any questions!
(585) 487-8220
alex @ rockhoptec com
1helpful
2answers
Kindle fire charging port replacement
Take it to a pc repair shop and have it done professionally. If your motherboard wasnt damaged... it can be repaired :)
www rockhoptec com
(585) 487-8220
alex @ rockhoptec com :)
2helpful
How to change charging port on my acer 5050
This is a much harder job than the average home user will be able to do. The entire notebook has to be taken apart. The charging port may or may not be built on the main system board which means maybe some fine soldering. There are a lot of companies that do this reasonably priced but depending on the age/value of the notebook you might look at just replacing it.
I have a gateway laptop which is not charging and even though i bought new chargers for it it still does not work i think the charging port is broken is there any possible way of fixing it without...
is the battery good? you could check and REFRESH it by discharging and recharging it many times in a row, as for the connector if it's directly soldered on the system board it can be replaced by an good experienced technician with the correct tools, if it is a connector with a peace of wire connected to the main board it is simpler for the user to change
2answers
Model # SRI45T25EUEI Unit starts to fill, float in matrix activates micro switch, then drains. Continues this cycle. No leak to base float.
It seems that the flapper breaks off or the spring cannot keep the drain port closed causing the water to drain as it fills,these are the usual defective parts.You might need to disassemble the pump and motor to get into the drain flapper area.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Mar 01, 2010 • Dishwashers
2helpful
2answers
N70 not charging
try replacing the charger or the charging point.
Samsung zv40
try another charger, if still doesnt charge, it means that the charging port on the main board needs to be replaced, very common with samsung
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
