Hi there! I'm sorry to hear that your Tchibo coffee maker is not brewing the large size coffee properly. Here are a few suggestions that might help:
- Check the water level in the water tank. If the water level is too low, the machine may not be able to brew the large size coffee.
- Make sure that the coffee filter is properly inserted into the filter holder. If the filter is not inserted properly, the machine may not be able to brew the large size coffee.
- Clean the coffee maker. The coffee maker may be clogged, which can prevent it from brewing the large size coffee properly. You can clean the coffee maker with a mild detergent and water.
- Descale the coffee maker. If the coffee maker is not descaled regularly, it can build up calcium deposits, which can prevent it from brewing the large size coffee properly. You can descale the coffee maker with a descaling solution.
If you have checked all of these things and the large size coffee is still not brewing properly, then you may need to contact Tchibo customer support for further assistance.
Here are some additional tips that might help:
- Use fresh, cold water. Stale or warm water can affect the taste of the coffee.
- Use a good quality coffee. Cheap coffee beans can make the coffee taste bitter.
- Grind the coffee beans to a medium-coarse grind. A too fine grind can make the coffee taste bitter, while a too coarse grind can make the coffee taste weak.
- Clean the coffee maker regularly. A dirty coffee maker can make the coffee taste bitter.
I hope these suggestions help!
