This is I think a test path used by Kenmore, what I think it does is to change from test to normal operation, there is a small button on the back of the refrigerator on the main control board, in order to get access there, you will need to unscrew the 3 bolts holding the board rectangle cover, once you get access there, you will see something like what is on the picture attached here.
hit the button twice to get to test, the display will show 8888 and all settings on the display will illuminate, press the button twice again and this will change to normal operation, press it twice again and it will change to 2222 again and so on.
Let me know if this helps, it worked on mine, however mine has a different fault, it does not cool only freezes.
Regards!
