SOURCE: My Epson NX 400 is giving me this error message:Error B88/69/68 C
Try to run the ink pad reset utility software.
Please log on to epson.com. The software runs on win xp and win vista.
SOURCE: epson rx680
one ink cartridge is out of ink but...
when we try to replace one of the color ink cartridges we get this error message:
ink cartridges cannot be recognized. make sure ink cartridges are installed correctly - how do I get the printer to recognize my full ink cartridge?
SOURCE: epson rx595 cannot recognize ink cartridge
Just had this happen to me. Turned it off, turned it back on... nothing. In/out with the cartridge several times and when I blew on the contacts of the printer (where the little microchio on the cartridge touches) it finally worked. Did the blowing on the contacts help? Maybe, but more likely is that the it was just repeatedly trying to d oit before the machine figured it out.
SOURCE: I just bought an Epson Stylus NX415 and the it
Sounds like you have either a defective cartridge but if both cartridges are not being recognized it's likely a problem with the printer.
Take it back to the store you bought it from for a refund or replacement.
SOURCE: Epson Stylus SX400 "Ink cartridges cannot be recognized"
Try this: First check which cartridge(s) are not being recognized. In my case where I replaced all three color cartridges, two were recognized right away but one was not. You find out by sending a print request to the printer and looking at the ink cartridge levels diagram in the dialog window. In my case two of three were fine but one had a red X on it. So I removed it and cleaned the contacts with alcohol then rocked it in the slot after pressing it in. It was recognized and the charging process began as normal.
