On HP PSC 2355 ALL -in -One. HP support did not solve the problem. Can you guarantee to solve this problem otherwise I dont want to waste time and money. Exactly the same ... happened a few days ago Weird??
The error is indicative of a hardware error.
Remove the power cord, hold # + 6 (semi-full reset) or # + 9 (full reset) buttons, then connect the power cord again, wait 3 secs (or until "Initializing Full Reset" appears on the printer display) and release the buttons.
This will set the printer configurations to its factory defaults.
Reset: Press the * and # buttons (simultaneously), followed by 1 , 2 , and then 3
Underware menu: Press the * and # buttons (simultaneously), followed by 1 , 2 , and then 4
Clear and reset NVM RAM: Press and hold OK and Cancel while plugging in the power cord.
If none of those work, it will need to be returned to HP as a failed unit.
SOURCE: wont print error message 165:hw_interrupt_hwv2.c also 0xb9000001
I moved the printer to a different area of living rooom, and when I plugged it back in now I get this same thing happening! I can't turn off power, and do anything.
