Frigidaire ATF6000ES Front Load Washer Logo
Janet Pittman Posted on May 31, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Won't spin after wash cycle or rinse cycle
After wash cycle or rinse cycle the washer will not spin. The clothes are still soaked. We checked the drain, and the drain is open. The pump is running that takes the water out. It is electric.
  • Janet Pittman Jun 01, 2009
    It is a Frigidare Model: LTF7000ES1. We are having a problem with the clothes being wet, and it will not spin. It is electric water pump. The pump is working. On the spin cycle the electric water pump removes the water. There is a seperate motor that turns the drum. It does not have a high speed spin. It works on the agitate cycle.
Anonymous
Level 3:
  • Master 6,784 Answers
  • Posted on May 31, 2009
Anonymous
Master
Level 3:
Answers
6784
Questions
Helped
2972463
Points
24702
CHECK THE FOLLOWING---
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
3 Related Answers
quady
  • 142 Answers
  • Posted on Sep 14, 2009
SOURCE: Washer will not spin at high speed
check for any blockages around pump and air trap area.
Anonymous
  • 85 Answers
  • Posted on May 18, 2009
SOURCE: washing machine does not drain during rinse cycle?
Turn timer to rinse cycle. let fill up and agitate. when it stops agitating it should pause then start to pump water out. After about 2 minutes it should pause for 3-5 seconds then start again and spin. If it starts the first time and never stops it will just continue to pump but no spin. The 3-5 second pause allows the transmission to shift to spin. If it does not do this the problem is your timer. You may need to do this a few times to verify the problem.
If that is not the problem it is likely that you need a new clutch. You will need a technician to install a new clutch for you
Anonymous
  • 6784 Answers
  • Posted on Jul 09, 2009
SOURCE: washer spins but won't drain, electrical smell
HI, the smell is coming from the pump housing. the pump impeller may have slipped of the drive stud, in return, jamming itself in side the housing. this will cause the pump to burn out. Check the following before you replace the pump.
1. Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2answers
My Lg too load washer sprays water during spin cycle
It is normal for a washer to spin and spray fresh water over the clothes during rinse period. I don’t know why it would leave clothes wet. Look at your options. See if you can turn off rinse n spin to just spin.
How to just run the spin cycle?
https://www.manualslib.com/manual/85754/Kenmore-29522.html#manual
Kenmore 600 Series Pdf User Manuals. View online or download Kenmore 600 Series Use And Care Manual. ... Kenmore Washer Use and Care Guide.
Probably the worst washing machine manual I have ever read!
Try this.
Put your wollens in the machine, set for cold water, Woollens Cycle and your 'Soak' detergent. It will agitate a bit, and as soon as it stops filling, turn it off.
After say 20 minutes. Then Move the dial to Spin, and pull the knob out. It _should_ pump out and spin.
My front load washer will not spin on the final spin cycle. Washer spins in wash and rinse cycle spin. Cloths are still soaking wet.
I appreciate your post, Rachel Kovach!
From my understanding your Frigidaire frontload washer is not spinning the final spinning and the clothes are still wet. If you washer is overloaded it will not spin properly to release the water out of the clothes. Also, a small load will cause your washer to not spin properly. You should additionally check the drain hose to make sure it not kinked or twisted that could cause your improper draining. If all that checks properly it could be an issue with your drain pump, motor, and control panel. I would suggest consulting with a technician for proper diagnosis and repair. This will help avoid unnecessary part purchases. -Matt
Washer will not turn on...
My washer makes a wierd clinky sound during wash and rinse cycle and it has began to stop spinning the water will drain but clothes will be soaked. Also sometimes during spin cycle it will agitate instead of spinning
6helpful
After the spin cycle runs the clothes are still soaking wet
I had that problem at one time with my old washer and what it ended up being was the Washer Dog Agitators were broken and causing the it to slip and not spin correctly. I would try checking the Dog Agitators.
Here's A picture of a typical top-load washer breakdown to show you where they are located --->Here<---
I hope this helps. If that is the problem I bought mine at Sears for about $8, normally in stock item.
moz-screenshot-2.jpgLet me know if there is anything else I can do.
5helpful
2answers
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
While the washer drains and spins, new water comes in
Drain hose must be at least 30 inchs above the floor.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Washer does nothing during rinse then leaks during spin cycle
hi thanks for the question i would check the drain hose your problem is the washer is not draining check the drain hose thanks the appliance doc
Maytag neptune won;t rinse
Check latch mechanism for alignment. Often operation of machine loosens latch mechanism causing internal switch for "door open (or ajar)" preventing rinse or spin cycle. Opening and closing door presses latch mechanism closing internal switch allowing for continue processing to rinse or spin cycles.
Top Frigidaire Washing Machines Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
