Also shows that printer is offline
SOURCE: Printer keeps saying insert memory card
The message is not an error message and does not indicate an issue with the product. The message is designed to be an invitation to print photos from a memory card. Follow these steps to insert a memory card into the product. For more information please check the link bellow: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01436439&cc=us&lc=en&dlc=en&product=3194498 Good Luck
SOURCE: the HP printer is connected but the icon shows "offline"
Go to control panel, then select printers. Then, from the list of printers (if you have more than one), right click on your printer and make sure "Use printer Online" is checked.
Hope this helps.
SOURCE: My printer is showing offline. I have unplugged
Try to right click your printer's icon. Check if the printer is set as the default printer or check if the printer is set to function online. It will not print if it was set to function offline.
