LG M237WA LCD TV Logo
A
Anonymous Posted on Jan 20, 2014
Lock key unlock onida
HOW TO KEY UNLOCK
1 Related Answer
Anonymous
  • Posted on Jan 27, 2011
SOURCE: need to key unlock my soniq 106cm tv
want to unlock the chanal,s on my soniq t.v. d.v.d combo
What is lock key of onida ultra slim 300tv
https://in.answers.yahoo.com/question/index?qid=20160118232909AAmsGvf
To unlock install option on onida tv you need to
• Press `TV MENU` repeatedly and
• select SOUND or press TV MENU
• once and select SOUND by
• pressing keys. `SOUND` is highlighted.
• Press up /down key to enter `SOUND`
• sub-menu . This Menu
• allows you to adjust the VOL LOCK,
• BASS (Low Frequency Sound),
• TREBLE (High Frequency Sound)
• and BALANCE.
• Vol Lock:
• A certain maximum sound level can
• be fixed beyond which the sound
• level cannot rise.
• ! Select VOL LOCK from sound
• menu using up/down keys.
• ! Vol Lock can be set `ON` or `OFF`
How to child lock my onida black tv
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Unlock procedure and to override the password lock of many popular brand TVs and other devices are given. Search the site by type in this key phrase "How to unlock television"; in the search box at the top left of the display window, to get gathered related posts...
Onida igo 14 inch volume lock key
1helpful
How to unlock volume lock on my onida tru slim 19 inch TV? Thanks for all your help in advance.
2answers
My onida tv volume is locked how to unlock it
You should have its remote control to unlock it. Without a remote control, you can't. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Unlock procedure and to override the password lock to many popular brand TVs are given.
1helpful
2answers
How to unlock onida ultra slim tv install
5helpful
I have replaced the batteries on the key remote control but it does not work
Programming
When
Key added or replaced. System malfunction.
How
Obtain all keys. A maximum of 3 keys can be programmed. Close all doors and boot/tailgate. Switch ignition ON. Repeat procedure below 3 times: Within 4 seconds: Press key lock or unlock button. Within 4 seconds: Switch ignition OFF. Within 4 seconds: Switch ignition ON. Within 4 seconds: Press key lock or unlock button. System should now lock or unlock vehicle. Within 4 seconds: Press key lock or unlock button. Within 10 seconds: Press lock or unlock button of first key. System should now lock or unlock vehicle. Press lock or unlock button of second key. System should now lock or unlock vehicle. Press lock or unlock button of third key. System should now lock or unlock vehicle. Switch ignition OFF. Remove key. Check operation of all programmed keys.
NOTE: If less than 3 keys are to be programmed, remove ignition key after programming last key.
237helpful
15answers
Deactivate child lock on Onida TV
Try with 1147 (This one worked on my ONIDA TV) OR 5963 OR PRESS ZOOM BUTON AND VOL- KEY BOTH.
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
