My mtd tractor (46/12) deck is cutting uneven when I turn right the deck lowers about 1" how can I fix it
Check your tire pressures:
10 psi. for rear tires.
14 psi. for the front.
Note that according to MTD:
Making sharp right hand turns. Twin-blade mower decks are designed with
the discharge on the right side and two side-by-side blades. The
side-by-side twin blade decks have the left hand blade positioned
slightly forward and in front of the right blade. This provides cutting
overlap when traveling in a straight line. As a result, the tractor
should mainly operated making primarily left hand turns when cutting.
During left turns this cutting overlap is maintained. If turning right
when, it is possible to negate this overlap and leave an uncut strip.
Did you check the air pressure in the tires...this will cause the deck to drop in the direction of the turn
Make sure the deck is level with a bubble type level called a torpedo level.
