The starter makes no noise and it wont turn over i have full battery power
SOURCE: turn key to start and it wont start, just makes a
if it is standard shift then check the clutch disable switch.... if auto then check neutral safety switch on transmission....confirm power to the starter itself.. report back
SOURCE: my 98 silverado wont crank over at all full
well it sounds like you need to replace the starter... have you checked the fuse and relay for the starter by chance?
The 05 suzuki verona with starter problem is not a starter problem it's the neutral safety switch on the transmission that went bad. Thanks anyway, Isis352
