Question about D-Link DP-300U (DHDP300U) Print Server
Print server prints non ascci chars and burns though all my paper
When I print on my HP4550 color laser printer I have to baby sit the DP 300U because once the print job is spooled it either works or it doesn't work. And lately it hasn't been working all that often. What happens is that it dumps symbols across the top of each page and goes through then entire stack of paper in the tray before it will quit.
Any Idea how I can prevent this problem? Would greatly appreciate it considering I have been living with it for years now.
Bruce
  • 39 Answers
Have you tried updating the firmware? If not, try this http://support.dlink.com/faq/view.asp?prod_id=2120&question=DP+300U+
Posted on Oct 23, 2007
6ya staff
SOURCE:
Can't find my usb Printer on my D-Link DP 300U (DP-300U) Print Server What to do anyone
ok have you tried changing the settings in the print server usually a printer must be configured on the print server before it can be used if it is on the network try telneting in to it through a web browser like you may a modem
Oct 13, 2011 | D-Link DP 300U (DP-300U) Print Server
Hp 1020 dp-300u
dont' worry about what the d-link site says. its because they haven't tested it. i got my dp-301u to work fine with my hp1020 on 2 different workstations with the following steps.
1. install printer locally via usb and test.
2. create a second printer as per the dlink manual creating a port. don't worry about the name as we will delete it.
3. once created go into the properties of the 2nd printer and change the port to something local - anything will do to free up the port.
4. go into the properties of the printer that was created in step 1. and change the port to that of the print server.
5. test print. should work fine.
cheers!!
Apr 13, 2009 | D-Link DP 301U (DP-301U) Print Server
FORGOTTEN PASSWORD IN DP 300U HOW RO RECOVER OR DEFAULT ABOVE PLEASEj
I had a similar problem to which i thought i had forgotten the password. Apperently the maximum length of the password the print server accepts is 8. It will show you all the chars you type in change password box but will store only the first 8 chars. If you tried a longer password type in the first 8 chars of your password and try. It worked for me and hope it works for you.
Mar 21, 2009 | D-Link DP-300U (DHDP300U) Print Server
Having to reset (unplug) daily
Check the Printer spool service. If documents are getting increase in que, restart the Printer spool services. It will definatly solve your problem.
Oct 03, 2008 | D-Link DP 300U (DP-300U) Print Server
Configuring a Mac Book Pro laptop with a DP 300U Print Server
I connected my HP5MP to the DP-300U LPT1 port.
I configured my port on the DLink Configuration tab, giving it a name "hp5"
...The default login is at http://192.168.0.10/ user:admin pass:(there is no pass by default)
On my Mac, I go to System Preferences > Print & Fax
Click the + to add a new printer
Select the IP option
Choose the Protocol: Line Printer Daemon - LPD
Type in the Address: 192.168.0.10
Type in the Queue: hp5
Print Using: Generic PostScript Printer or better yet, 'Select a driver to use...'
and find the driver for your HP LaserJet 5MP.
Save it. Works like magic. ;-)
If you change the IP address or password on the DLink, just CYA and write it all down on a sticky note then tape the note under the DLink chassis. There's no reset button on the thing, and if you're o a Mac, you won't necessarily have access to the Windows utility to jack with the DP-300U. So, write it down, kidd-o!
Sep 07, 2008 | D-Link DP 300U (DP-300U) Print Server
DP-300U revB and KONICA MINOLTA bizhub 163
I have just setup DP-300U rev.B1 with my Konica Minolta Bizhub 162, the thing is that it doesn't work with USB port connected (paper out), then I tried connecting Bizhub 162 to LPT port, and it works just fine...
Jul 17, 2008 | D-Link DP 300U (DP-300U) Print Server
D-Link Print Server Compatibility issues
DP-300U Print Server is not compatible with Sharp AR-5320. Pls check D-Link website on the list of compatible printer. For USB Print Server that is compatible with Sharp AR-5320 try Intellinet.
Jan 27, 2008 | Sharp AR-5320 Black and White Copier
DLink DP-300U Print Server
What is the IP of the Print Server and the Printer itself? They have to be on a 'flat network' or the gateways of the the 'adjacent' networks have to be defined as a neighborhood.
Nov 15, 2006 | D-Link DP 300U (DP-300U) Print Server
D-Link DP-300U (DHDP300U) Print Server Logo
286 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Ekse
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
