Where do you find a new connector for the dvx 620?
SOURCE: No sound when piano keys are pushed on my Yamaha dgx-620
I'm sorry but it sounds like you will have to have it repaired professionally.
SOURCE: Right half of lcd screen on yamaha DGX-620 screen
I have the same Problem since yesterday my granddoughter hit the keyboard too heavy. I have opened it (many screws...) but could not find any obvious reason. Nothing like a loose connector.
SOURCE: I require a complete set of fixing bolts for a
If you contact Yamaha keyboards and tell them the model of your keyboard they can tell you exactly what part numbers they are and tell you how to order them. Here is the link: yamaha24X7.com.
SOURCE: Which midi cable or USB midi cable should I use for Yamaha DGX 520 model.
It doesn't use a USB to MIDI adapter (such as the UX-16.) It has an onboard MIDI controller and uses a standard USB A-B cable. You just need to install the driver from the CD-ROM or here, and plug it in. You can get the manual from the same page or here. Setup is on page 99.
