Canon PowerShot SD750 / IXUS 75 Digital Camera Logo
Tamara Greco Posted on Jan 21, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Flash not working hoe can you tell if light bulb is burnt
Harrie
Level 3:
Top Expert:
  • Canon Master 6,746 Answers
  • Posted on Jan 21, 2014
 Harrie
Canon Master
Level 3:
Top Expert:
Answers
6746
Questions
0
Helped
1283780
Points
83153
Hi Tamara. Only a technical can tell, when opening the flash. (In your case the whole camera.) Sometimes, when you look very good, you can see the light bulb is black on one (or both) side(s).
But usually the technician would measure the high voltage on the capacitor and wheel the flash is triggered he will check if the thyristor fires. But not being a technician, please don't open the camera and never play with an open flash light, because the voltage even in a small camera can be very hight.
3helpful
2answers
Indicators not working
That is a common problem when one of the turn signals bulbs is out. check the light bulbs on the side that is not working or the side that the dashboard flashes quicker. replace the light bulb front or rear. take a good look at the light bulb filament inside. some times is not easy to detect some other time the light bulbs will be light black powder inside if they are bad. if the light bulb does not fix it also check for the fuses may always be fuse as well.
Deivers tail light/brake light do not work..reverse works..when i lock my car the lights flash except for that one and the drivers light..headlights work fine though.drivers headlight bulb connector looks...
Could be a broken wire at the socket. Sounds like a burnt bulb also. Sometimes a burnt bulb will do the same thing as you are describing. Once you get this fixed, all should work. If flashing to quickly, replace the flasher stat unit!
3answers
1993 plymouth acclaim turn signal flashes rapidly, new flasher didn't work.
bad earth on a back light i suspect providing their europeon standard lights with yellow seperate indicators and not them funny american ones with a stop and tail and indicators all on the one bulb
2answers
When i use the sighnal it flashes fast and only the front lights up the back dosent but the brake lights do light up
The fast blink signals that you have a flasher bulb burnt out, as I suspect you do in your rear turn signal. The flasher sees a voltage drop through the burnt out bulb and signals a fast flash.
2helpful
2answers
Right turn signal flashes fast
One of the bulbs is burnt out. Turn on hazard lights and check bulbs.
1helpful
2answers
Flashing red light
the ballast needs to be replaced.
7helpful
Indicator Problem
when you noticed the indicator being on solid, but flashing with the hazards, are you inside your car? I mean have you gotten out of your car to check if the bulbs are working when the indicator thrown and when the hazards are on. A hard on indicator usually means that you have a bulb burnt out. The hazards will still flash as normal when inside the car even if a bulb is burnt out because the hazards do not run via the Electronic Flasher Module. The EFM is what detects a burnt out bulb
5helpful
4answers
LEFT TURN SIGNAL FLASHING TOO FAST
when a turn signal indicator flashes faster than is normal it is your vehicles way of telling you there is a problem with the lighting system, do a visual check of your turn signals and you will find a burned out bulb. just replace the bad one and it will return to normal
Left rear brake light stopped working but bulb and fuses are OK.
These are Dual Function Bulbs. They control the Parking Lights and the Brake Lights. This Bulb is Burnt out on the Brake Coil inside the Bulb. I have actually seen Bulbs that were Bad But you could not Tell by jast looking at them. It should be fine with a New Bulb. Please Rate My Response! Thanks!
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
