Franklin Industries Franklin Chef Ice Cube Machine FIM400 Logo
Green light is on - Franklin Industries Franklin Chef Ice Cube Machine FIM400
I need a stereo wiring diagram for a 97 mercury villager gs
1997 Mercury Villager Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Green/Purple
Radio Ignition Switched 12V+ Wire: Yellow/Black
Radio Ground Wire: Black/Light Green
Radio Illumination Wire: Green
Left Front Speaker Wire (+): Orange/Light Green
Left Front Speaker Wire (-): Light Blue/White
Right Front Speaker Wire (+): White/Light Green
Right Front Speaker Wire (-): Dark Green/Orange
Left Rear Speaker Wire (+): Light Brown/White
Left Rear Speaker Wire (-): Light Brown/Yellow
Right Rear Speaker Wire (+): Light Brown/Green
Right Rear Speaker Wire (-): Brown/Pink
2000 villager radio wiring diagram
Constant 12V+ Green/Purple Switched 12V+ Yellow/Black Ground Black/Light Green Illumination Green Dimmer n/a Antenna Right Front Front Speakers 5" x 7" Doors Left Front (+) Orange/Light Green Left Front (-) Light Blue/White Right Front (+) White/Light Green Right Front (-) Dark Green/Orange Rear Speakers 5" x 7" Side Panels Left Rear (+) Light Brown/White Left Rear (-) Light Brown/Yellow Right Rear (+) Light Brown/Green Right Rear (-) Brown/Pink
Diagrama de arnes autoestereo ranger 2000
Here are all the details for stereo wiring
• Constant 12V+ - Green/Purple
• Switched 12V+ - Yellow/Black
• Ground - Light Green or Black
• Illumination - Green
• Front Speakers 6" x 8" Doors
• Left Front (+) - Light Green and Orange
• Left Front (-) - White or Light Blue
• Right Front (+) - White/Light Green
• Right Front (-) - Dark Green/Orange
• Rear Speakers - 6" x 8" Side Panels
• Left Rear (+) - Light Brown or White
• Left Rear (-) - Light Brown or Yellow
• Right Rear (+) - Light Brown/Green
• Right Rear (-) - Brown/Pink
To know more, check this link: https://www.the12volt.com/installbay/stereodetail/2388.html
Factory color coding for stereo
Windstar Car Stereo Radio Wiring Diagram - All years
Car Radio Constant 12v+ Wire: Green/Violet Car Radio Switched 12v+ Wire: Yellow/Black Car Radio Ground Wire: Black/Light Green Car Radio Illumination Wire: Green
Left Front Speaker Positive Wire (+): Orange/Light Green Left Front Speaker Negative Wire (-): Light Blue/White Right Front Speaker Positive Wire (+): White/Light Green Right Front Speaker Negative Wire (-): Dark Green/Orange
Left Rear Speaker Positive Wire (+): Light Brown/White Left Rear Speaker Negative Wire (-): Light Brown/Yellow Right Rear Speaker Positive Wire (+): Light Brown/Green Right Rear Speaker Negative Wire (-): Brown/Pink
Speakers
1995-1998: 5" x 7" Front door and side panel 1999-2003: 6" x 8" Front and rear door
I need a copy of the wiring diagram/color code for the colby stereo system in a 90-FORD AEROSTAR
90 Ford Aerostar Colby Stereo System
Wiring color code:
Speaker Power Ground
Left Front Orange/light green Light Blue/white
Right front White/light green Dark green/orange
Right Rear Tan/light green Brown/black
Left Rear Tan/white Tan/yellow
Other Wires:
Yellow/black = Hot - Key On
Light green/yellow = Hot - Direct to Battery
Light blue/Red = Radio lights
Black = Ground
Black/light green = Ground
This is what I found for you,hope it helps. Good luck.
Wiring schematics for a kenwood kdc-mp145 to a 1998 ford ranger
Battery light green to yellow
Accessory yellow/black red
ground black black
Illumination light blue.red orange/white
Power antenna amp=blue blue
LF + orange/light green white
LF - light blue/white white/black
RF + dark green/orange gray
RF - white/light green gray/black
LR + gray/light blue green
LR - tan/yellow green.black
RR + orange/red violet
RR - brown/pink violet/black
Need factory wiring codes for a 1999 jeep grand cherokee
battery red/white
accessory white/red
ground black
LF - light green/green
LF + light green/red
RF- light blue/ black
RF+ light blue/red
RR- tan/dark green
RR+ white/violet
LR- white/dark green
LR+ dark green/white
Dimmer orange
This wiring is for the standard audio system
3helpful
1996 Camry Tail ights not working
So its a wagon? or I dont know what S/W is. If the license plate light works, the light failure sensor could be bad. It should be in the left rear corner area and have 4 wires. Green, Light Green, Yelow/Green and White/black. You should have power on the Green going into the box, and the Light Green out to the tail lights. If you have power on the Green, but no power on the Light Green, then the box is bad, either replace the box, or you can just connect the Green to the Light Green wire to get tail lights operating.
2answers
Had to cut the factory harness
trick of trade... take a 9 volt battery and touch the wires to it.. the speaker will pop and you will know which one is which... do one color at a time
1helpful
My cm2130 battery doesn't charge in my compaq presario 700 laptop
red light = 25%
Red + Green = 50%
Red + Green + Green = 75%
Red + Green + Green + Green = 100%
Top Franklin Industries Kitchen Appliances - Others Experts
john h
Are you a Franklin Industries Kitchen Appliances - Other Expert? Answer questions, earn points and help others
