I want to take pictures off my SD card and put them in the camera's internal storage,how do i do that?
Although most cameras do have an internal memory, the space is very limited. Most of the time you can store on or two pictures. When you shoot in lowest quality, perhaps 10.
If the internal memory is full you can move the pictures from the internal memory to a SD memory card. Not the other way around.
For this see the manual (English) page 33
SOURCE: computer will not recognize memory card
Check two things and let me know how it goes.
1) Are you putting the SD card from your camera into a slot on your laptop, or pc? Or are you putting it into a card reader?
2) Are you sure the switch on your card is in the unlocked position? Let me know if any of these doesn't work.
Rob
SOURCE: my s500 will use up 16 in camera picturs i put a
Turn the camera on and activate the menu. Look for a menu option similar to "Image Storage" and either choose the card or auto. Save your choice and exit the menu. You will most likely have to format the card. Again, activate the menu and navigate to the FORMAT command and format the card. The camera must format the card, not a computer. Now when you take photos, they will be saved to the card.
SOURCE: I have a Sanyo VPC-E760 digital camera that I
first ..choose a picture that ya know that is on the internal memory ..and see if it has options ...it usually has....there you will find option for move ..or transfer ..or so ...if it doesn't have ..you got to fins a suitable data cable ...and use the driver ...to do the job ...(it might also download with a photo manager acdsee like and using the import from device feature ..)
SOURCE: My camera says it can not read the memory card and
You can use a card reader to download the pics and then you can format the card in the camera. This one costs $13 at Walmart and can read 32 different cards.
SOURCE: I have a sanyo vpc-s600
Open your picture by browsing mode (play back). And then open the menu there is a faction of copy, and you can choose all of the picture and copy them to your card. Have a try and to see if it's helpful
