Brand new camera will not turn on after fully charging battery.
SOURCE: When switching camera on it won't turn on
It could be the battery is not fully charged and the other thing is the main switch in the camera could be bad .
If any further assistance needed contact .
Also it could be a main circuit bad .
Berrie Smith Camera Repair
SOURCE: Camera shows battery exhausted with new batteries.
I have the same problem with my coolpix L101. Even rechargeble nimh battery's with high capacity (2500 mAh) are empty after 3 shots.
SOURCE: MY NEW NIKON L22 CAMERA GIVES ME AN ERROR WHEN I
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine .
Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a
back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec ..
in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success.
SOURCE: I have a brand new
The solution to your problem is simple, Kathrynbax.
The battery never comes in fully charged. It's always charged only so you may be able to check if your camera is working. I suggest, you take out your battery and put it to charge for exactly 90 minutes as the manual says. Then I'm sure you won't face any such problems.
Hope this solves your problem.
Good day!
Rebel
