White clothes are coming out stained, it looks like fabric softner stains , but i have not used any fabric softner in thew machine. I wash in cold water and use powered detergent.
SOURCE: Washer leaves fabric softner stain on white clothes
Dispenser wholes are probably clogged and all the softener is not dumping when it is supposed to!. Top loaders usually have a little cup like place to add the softener in the top of the agitator!
Those the Manuel tells you to rinse with water occasionally!
If you can't figure it out, call service and get it done and over!
You will feel better!!!
These guys are good
A&E Factory Service is nation wide!
1800-905-9505
They are open 7 days 24 hours to make appointments
Neil
SOURCE: "fabric softner staining the clothes"
make sure you delute it with water. yes fabric softner will start to stain your clothes if you use too much of it. I would recomend stop useing it for a while. so you can clean the washer out. There is a product called Washer magic or Affresh that cleans out residues built up in your washer. or you can just run several loads of HOT water and bleach to clean it out. The hot water will melt the left over fabric softner in your washer. Fabric softner is kind of like hardend bacon fat thats what it looks like in your washer after time and if you do not clean your washer it builds up and builds up.
Also i do recomend alternating liquid detergent and powdered detergent. The reason why is powder leaves a residue that liquid takes away and vise versa. try this and let me know how it goes
SOURCE: My Washing machine stains clothes;
I had the same problem, and it turns out that it is NOT the seal. It is the liquid fabric softener. The fabric softener dispenser needs to be cleaned periodically or it gets a black waxy, goopy, build up. It is this same buildup that ends up staining your clothes with dark brown or black stains. Just remove the dispenser and wash it our very well and the problem will be gone.
