SOURCE: Refilling Ink in Canon Pixma MP830
Hello, I found this in a repair manual for the MP830. summery is to press and hold the stop/reset button for 5 or more seconds. I copied the info from the manual too. The remaining ink amount unknown. [1683] (Applicable ink tank icon) The remaining level of the following ink cannot be correctly detected. An ink tank which has once been empty is installed. Replace the applicable ink tank with a new one. Printing with a once-empty or refilled ink tank can damage the print head. If printing is continued without replacing the refilled ink tank, press the Stop/Reset button for 5 sec. or longer to record the use of a refilled ink tank. Note: After the above operation, the function to detect the remaining ink amount is disabled.
SOURCE: Ink Cartridge Refill Error E5
First take a smooth cloth or cotton
take a cleaning liquid like spirit, thinner etc., (note - not cleaners)
clean the golden chip with out giving much presser
in the same way clean the other side of the printer also
now test it
90% Problem will solve
Thanku
Take care
Bye
SOURCE: Canon Pixma iP2000 wont print black ink?
Canon IP 2000 / reset
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
SOURCE: Canon ip2700 after refill of
For your ip2700, even if you reset your refilled cartridge, they are not going to be usable.
After 4~5 times of color refill, you will see e5 error that cartridge is not readable anymore.
So you need to replace your cartridge with new one somehow.
If you would like to save money, try refill kit by "ROADINK".
Not only they are easy, but also the printing quality is good.
For your better understanding pls check out my youtube video.
And will see how easy ink refill can be done.
SOURCE: The black print won't print, but colour does,
your black ink cartridge got bad sprayer nozzles now you gotta replace it
and why the other color one is not bad yet cus printer as will known will depend on black ink far more so the black cartridge is heated up more times
