Whirlpool Cabrio Washer WTW6600S turns on but does not do nothing
All the lights turn on and it wants to do something but no water comes out and nothing. it does not clean itself or nothing. is there someway to reset the washer.
Try to turn the drum by hand, if it hard to turn, there may be something stuck underneath spin basket. If it does turn freely but makes a loud growling sound, you probably have a bad bearing. You should notice black oil and water mixture at bottom of washer, on the rotor. It will usually throw a f51 error code. This unit has service bulletin on this problem.
mine just started doing this on the wash cycle then we have to turn it to drain and spin. Last night it filled with water and refused to do anything else so it said it was done, open the lid and still full of soap and water. Turn it to drain and press the start button and it does nothing, no lights come on. We bought it in 2012, before the washer we had was purchased in 2000, and we are still using the dryer from 2000.
Sorry to say you have a shortage,which means it must be replaced in order for your washer to work. It appears to be worn and thats preventing it from catching or starting..Good Luck.
HE Top Load Washers Models: F1 Error Code WTW6200S WTW6300S WTW6400S WTW6600S WTW6700T MTW6300T MTW6400T MTW6500T MTW6600T MTW6700T Serial Numbers: CT01 - CU52 There are four areas of concern that can cause the F1 Error Code. Each area must be sequentially addressed to ensure that the diagnosis is correct and the proper repair is completed. A) Air leaks in the air pressure (switch/sensor) hose. a. Inspect the hose for cracks, pin-holes or loose connection. b. Replace the hose and harness assembly (W10058730) if it is compromised. B) Moisture in the air pressure (switch/sensor) hose. a. Inspect the hose for evidence of water. b. Replace the hose and harness assembly (W10058730) if water is detected. C) Lint or flashing in the air dome hose connection port. a. Inspect the air dome hose connection port for lint or flashing. b. Use a small round device (small screwdriver) to ensure that there is nothing blocking the air dome outlet on the tub. D) The control needs to be replaced. a. Replace the control only after you have completed steps A - C above, and verified that there are no issues with the air pressure system.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&^@#$%
Are you referring to the Whirlpool Cabrio WTW6600S Series of washers? They don't use an agitator like a conventional washer. They have a movable wash plate located in the bottom.
the ld code means a long drain, what you probably have is something blocking the drain pump. you can get to the drain pump from the back of the unit and it will be the pump on the left as you face the back. you will need to remove the hose going into the pump and be ready for water to come out. sorry but you need to check inside the hose as there will be something blocking it. like a coin or some lint or a small sock. when you get the item out of the hose then it should work again. you do not need to reset the control. once it knows the unit is draining properly it will be ok.
