Toshiba 36A50 36" TV Logo
A
Anonymous Posted on Jan 19, 2014
Time warner remote code list - Toshiba 36A50 36" TV
1 Related Answer
Anonymous
  • Posted on Dec 10, 2008
SOURCE: time warner code for Fujitsu 42" tv
I have the 55 inch. try using 246. That works on mine. if not try 028,164,208,066
let me know if that works for ya
ric
another note, are you using the flash on the back of your cable box or do you have a sensor in front of the DVR box?
1helpful
What is code for Seiki TV?
Search Results
    Remote Control Code for Seiki TV - TWC Community Forums
    forums.timewarnercable.com/.../Remote...Code...Seik...
    Time Warner CableJun 5, 2013 - Does anyone know the correct code to use for programming the remotecontrol with the Seiki TV? ... The one they have listed for Time Warner is a 4 digit code(0178) so it doesn't work. ... I did some research and it appears LG or Samsung codesmay work for Seiki sets.
    Seiki TV remote code - High Def Forum - Your High Definition ...
    www.highdefforum.com > ... > DISH Network Forum
    Jan 30, 2011 - 7 posts - ‎6 authors
    I purchased a 32" Seiki TV but there is no listed remote codes for this brand. Does any one know of a code that will work? Thanks.
1helpful
Tv remote codes time warner cable
275,270,274. Try these codes. If you wish to get more, try the following links. Both the sites linked have set-up code list & set-up procedure to many popular brand remote controls. Surf the sites with patience.
http://electrohelponline.blogspot.com/
http://electro-medical.blogspot.com/
32helpful
2answers
Need Time Warner Remote code for LG 42LB5D HDTV
For Time Warner Cable digital remote controls to work with your 42" LG HDTV, do the following:
1. Press "TV" and "OK" simultaneously for 3 seconds, until the button "tv" light on the remote is on.
2. Enter the TV code. In this case, it's "113". With the right code, your component will turn off. Quickly press the power button on your digital cable remote to turn it back on. Press the "TV" button again so that the remote saves that code.
3. You should be done.
How do i program this remote to my time warner cable box
Time Warner is most likely made by another company and they are not listed on the programming documentation. You can try looking online to see who makes your Time Warner box. You should be able to program the manufacture off of the program list. The universal code for this remote is 8107 and 8108 which may work as well. To program the remote press set and the light next to set will start flashing. Press the desired component button ex(TV , VCR, CBL, DVD). Next enter the code 8107 and press ENTER. The set light should no longer be flashing. If 8107 does not work try 8108 using the above info.
2helpful
2answers
Time Warner codes for remote set up
Timer Warner Remote code for Vizio TVs: 1758 1756 0864 0885 1499.
11756 10864 10885
1helpful
Dynex remote code for time warner hdtv converter
use 164....not 169 as is listed all over the web and incorrect.Good luck!
12helpful
10answers
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
