SOURCE: GE SIDE X SIDE Dispenser problem
Sound like maybe a dispenser board short... you could try taking of the top hidge cap on the freezer side unplug the power to the board there for 30 minustes or so plug back in and see if it can reset to default and try that before u have to change board
SOURCE: GE ESS25XGMC WW Side by Side
its possible that your water tank has frozen up, try turning the refrig off and leave the doors open for about 10-15 mins and try it again. if that works just reset temp controls a little lower..
SOURCE: GE TFX22CR Ice Dispenser inoperative
Check the ice maker see it is in the right position, maybe you can try pull out the ice maker and clean it and push it back, make sure the position is right.
SOURCE: I have a GE side
Well, the solution to this problem was posted in this thread
http://www.fixya.com/support/t1295372-ge_profile_ref_ice_despenser_motor_not
It seems that the bulb in the front panel is pulling to much current as it ages and it makes the control panel in not work properly. Removing the bulb will fix the problem - just fixed mine.
Also seems to match your symptoms (works sometimes and then not others - bulb current is inconstent, light dims when dispense lever pressed - again wrong current draw).
Good luck
SOURCE: Water is not dispensed but icemaker is working
It's more common to be frozen in the door.
You can disconnect the line under the
unit before it goes into the door at the bottom hinge. Push the dispenser
button and see if it comes out there. If it does leave the door open till it thaws
If it doesn't come out then disconnect
the line to the water dispenser at the water inlet valve on the back where the
water supply comes in and try the dispenser. if you hear the valve work but
water doesn't come out, the valve is bad. If the water comes out then check the reservoir.It's behind the crispers in the fridge.
Testimonial: "As I posted, I'm not sure what the problem/solution was, but its working now. Thanks a lot for pointing me to the crisper!"
