Want to set personal greeting on handset.
Select the model of your Uniden DECT 6.0 system from the list beginning at http://www.uniden.com/scat/dectphones_mnl to download a copy of the manual.
SOURCE: I have a Uniden DECT 6.0 phone set. I damaged one
On the base, open the menu and select Register Handset. The display should say Handset Registering.
On the handset you want to register, press and hold # until the handset display says Handset Registering (about 2 seconds).
1.
2.
DSL filterTelephone cordTelephone wall jack
45
In about 30 seconds, the handset display should say Registration Complete. Press Talk/fl ash and make sure you get a dial tone.
If...
Try...
you don't hear a dial tone
the display says Registration Failed --
Making sure the handset is fully charged, then start over at step 1.
SOURCE: Yesterday afternoon both handset 1 and handset 2
You need to replace the rechargable batteries. They are quite expensive, $30.00 each, but thats likely why they are dead.
SOURCE: i can't get my uniden handset to stop blinking and
on the cradle of your phone there is a button that says FIND press and hold that button for 15 seconds. I, called the co. and was given said instructions. It, worked.
SOURCE: uniden dect 6
Since you declined to specify the model of your Uniden DECT 6.0 system, I can only suggest that you select it from the list beginning here to download a copy of the manual.
SOURCE: I bought 2 sets of
Deregistering Handsets.
Press & hold the "END" & then the " # " Key. Continue to hold the two keys until a menu comes up. Select "Deregister Handset". When it asks which handset, select the handset number that you are using.
To register a handset, simply place the handset in the main base unit. You'll the main ans mach bases on for both sets to do this.
