Juicers Logo
R
Rose Tesoriero Montoya Posted on Jan 20, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Tiny plastic piece at end of spout fell off
The clear piece that goes by the spout where the juice comes out fell off. I cannot place it back in correctly -cannot find the right position - and every time I make juice it pours through the tiny hole or is stopped up.
  • Anonymous Jul 26, 2019
    You just need to force the rubber nipple through the hole (downward) on the metal spout. You may need to use pliers to assist. It will pop in.
  • Anurag Yoga
    Anurag Yoga Aug 20, 2019
    where can i get rubber nipple for the juice spout?
Terry
Level 3:
  • Jack Lalanne Master 11,377 Answers
  • Posted on May 09, 2018
Terry
Jack Lalanne Master
Level 3:
Answers
11377
Questions
Helped
4626210
Points
152765
4 Related Answers
Anonymous
  • 6 Answers
  • Posted on Oct 21, 2008
SOURCE: Juidelady jl500 juicer replacement parts
I also have a Juicelady, & need a part(s) HEre is a probable solution to your problem!
In the U.S.A. or Canada call 1-800-233-9054 to order the part. Or see if they have it in stock.They will ask for your address & phone number. Have your serial number ready-it should be on the bottom (or possibly the side) and you may need a magnifying glass to read it! It starts with the letters JL, and mine was JL500 (so look for that-but your may be a different model, I gave you mine so you have an idea of what to look for.)
Note: Anywhere else, or to check them out online:
The same warehouse is also at foxinternational.com if you'd rather see what they offer that way--but we got our call answered after waiting les than a minute. They even had the part we require but won't ship to Canada, so if your Canadian--call anyway, as it is a different part than we required,( the arms that brace the unit together.)
Hope this was helpful for you!
Anonymous
  • 356 Answers
  • Posted on Jun 30, 2009
SOURCE: shuts itself off when juicing
FIRST DUMP THE FILTERS, THEY DECREASE YIELD AND MAY CAUSE MORE VIBRATION.
IF JUICER SHUTS DOWN PUSH RESET BUTTON ON BOTTOM. THIS TYPE OF JUICER DOES
NOT EJECT PULP AND REQUIRES SOME TIME TO MASTER. FEED THE STUFF SLOW AND
STEADY. WANT A GOOD JUICE? TRY 1 APPLE, 2 CARROTS, 2 CELERY AND A HALF LEMON.
IF YOU ARE REALLY BRAVE YOU CAN FINISH OFF BY SLOWLY POURING 6 OR 8 OUNCERS
OF WATER RIGHT DOWN THE CHUTE. THIS NOT ONLY DILUTES BUT LEECHES MORE JUICE
OUT OF THE PULP. JUICE SHOULD BE DILUTED AND DRANK SLOWLY.
Lance Hill
  • 1739 Answers
  • Posted on Mar 29, 2011
SOURCE: I have an older model
Is this your product:?
http://www.alessi.co.uk/ashop-uk/design-products/kitchen-accessories-90143/citrus-squeezer-1018.html
Some Alessi replacement parts are available on-line here; have not seen anywhere else:
http://www.alessi.co.uk/ashop-uk/offers.php?mode=offer&offerid=313
You need to know the spare part # to be able to order and it may be easiest to simply contact Alessi by e-mail to make a parts inquiry:
http://www.alessi.co.uk/ashop-uk/help.php?section=contactus&mode=update
The alternative would be to visit the nearest Alessi dealer, see here:
http://www.alessi.com/en/stores/search-flagship
Anonymous
  • 710 Answers
  • Posted on May 20, 2011
SOURCE: CARROTS ARE BACKING UP THE
Hi Catherine,
Can you supply the model number please?
Thanks,
Handie Andie
1helpful
In the middle of juiceing, the machine abruptly stopped.
Some juicers have an automatic shut off in them that prevent the motor form burning out.
When mine shuts off, it invariably means it got backed up and some produce in on the blade or in the shoot..clearing that out and then turning on with mine --the juiceman turns it back on.
On my vitasmix and garbage disposal it has this motor saving feature but there is a little button ypou must hit to rest it. sometimes it comes right back on when the button is hit but sometimes waits as the motor is not sufficiently cooled down and will come back on when a short time passes.
Maybe juicing less stuff at each push will help. Mine tends to do this when I am juicing very rapidly and jamming stuff in or when something extra hard is in there and the motor overheats trying to cut it perhaps smaller pieces might help if the produce is hard or very fibrous.
Mar 02, 2015 • Juicers
My juicer leaks under the spout. I can not figure out why. I have checked all the assembly and all the directions. It is only the second time I have used this. My machine is brand new. Any though
The spout, itself is hinged. It has two positions, an upper and a lower position. (Similar to a light switch). Make sure it is in it's lowest position when making juice, otherwise the liquid will collect in the inner bowl and leak out the sides of the juicer. Move the spout to the upper position to temporarily stop the flow of juice, such as when you change glasses or receptacles. Then, put the spout in the lower position to resume the flow of juice.
1helpful
2answers
I am trying to disassemble. I have done it many times, but the basket won't come off the base this time. I have poured hot soapy water through in forward and reverse. Not working
Many times when juicing very fibourous produce the bowl(basket) can get stuck and you can loosen it by gently tapping on the pulp spout or juice spout to the counter clockwise motion(right), this will loosen the bowl.
I need to remove the parts for washing How I do this?
Things You'll Need:
  • Soft-bristled brush
  • Stiff-bristled brush
  • Dishwasher (optional)
  • Mild detergent
  • Lint-free microfiber cloths
  1. Unplug your Acme 6001 Juicer. Carry it to a countertop near your kitchen sink.
  2. Remove the pusher and cover, and set the pieces in a sink. Unscrew the clutch, remove it and set it in the sink. Remove the cutter blade, strainer basket and juice bowl, and place the pieces in the sink.
  3. Discard or remove and store any pulp that you find in the strainer basket. When you're finished, rinse the remaining fruit and vegetable pulp and juice from the pieces under cool, running water. Dislodge hard-to-remove pulp from the cutter blade and strainer basket with a soft-bristled brush or with a stiff-bristled brush if necessary.
  4. Wash the pieces in a dishwasher or by hand. To wash in a dishwasher, place the stainless steel pieces in the lower rack and the plastic in the top rack and wash on a normal cycle with other kitchenware. To wash by hand, fill the sink with warm water and a few drops of mild detergent and wash with a lint-free microfiber cloth.
  5. Run the pieces through the rinse cycle in your dishwasher or rinse under running tap water by hand. Air or wipe dry the pieces.
  6. Wipe the base with a slightly soapy cloth. Rinse with a damp cloth and wipe dry. Reassemble your juicer by returning the pieces to the base in reverse order.
     for a visual:http://www.youtube.com/watch?v=alumocbDHg4
     "DON'T FORGET TO VOTE PLZ"
2helpful
2answers
Plastic arm bracket to hold bowl and cap in place while in operation snapped. Can I replace this piece?
wait if you have the old 1000 the new latch arm will not fit i tried it but if you the new 1000 go to omegajuicersdirect.com and find parts and email paula for info
Can't find the manual and have forgotten how to take it apart to clean it
Most juicers have a retention rod or side snaps that hold the top of the juicer in place. By loosening these, it will allow you to get underneath the juicer cap top. Once you have done this, you will have to remove the juice/ pulp wheel blade. Your juicer should have come with a two pin tool that facilitates this. Use the tool to loosen the juice /pulp wheel blade. Once you have done this, you should be able to remove the outer juice capture rim with that has the spout on one end. I hope this helps. Good luck and happy juicing.
Jul 18, 2010 • Juicers
2helpful
2answers
Shuts itself off when juicing
1helpful
Juice lady
On the stainless steel basket notice a notch cut out on the rim above the spout and an indentation on the back of the basket near the rim. The plastic ring must snap on to the steel basket before placing the assembly on the motor housing. If it does not snap on, it is not fully seated. After the ring is seated and on the motor base, push the basket on and spin it. Confirm that the basket clears the ring. Place the top cover with feed tube over the unit and lock the two clips down. This procedure should solve your problem.
3helpful
Top Jack Lalanne Juicers Experts
ADMIN Andrew
ADMIN Andrew
Are you a Jack Lalanne Juicer Expert? Answer questions, earn points and help others
