No Water flow thru Humidifier
Loosen the brass fitting where it connects to the soleniod valve. If water comes out your saddle valve is ok. Carefully retighten this fitting. With the humidifier turned on loosen the first fitting down stream from the valve see if water comes out. if it does turn the humidifier off and see if it stops, it should. That will tell you the the valve is ok then, just clean the filter and the oriface. if it does not turn on and off check the wiring. if ok replace the valve.
Good luck
Hi George toliopoulos, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box? Took apart the tubing and both tubes are clean. Water does not pass thru the control metal connection
Both sides of the tubing are clean. It seems it not going thru the control metal that the tubes connect.
Both sides of tubing are clean it seems water is not going thru the metal control.
