The toilet sounds like a choo choo train after its flushed. Why?
SOURCE: grinder wont turn and toilet not flushing
Disconnect the power and pull the pump out and examine the pump. Simple and easy!
SOURCE: Shortly after toilet flushes, you hear a tinkling
Check the water level inside the tank to be sure the tank isn't overfilling and spilling into the overflow tube.
Also check the flapper valve (the rubber valve at the bottom of the tank that sits over the flush hole and is connected to the flush handle) to be sure it is holding and not leaking.
Make sure the handle chain that goes to the flapper valve isn't tangled up and holding the flapper valve partially open.
SOURCE: When flushed, the toilet (sounds like a lite scream)
try to replace the fluidmaster it is either that or your supply line is kinked,that or check the little black hose inside the toilet tank make sure that hose is not kinked,if neither hose is kinked replace the fluidmaster
SOURCE: My up flush toilet makes a humming sound every 5
The pump has either gone bad or it is siezed up...you can try to unplug the pum and let it sit for a few hours then plug it back in... sometimes if you jog it on and off a few times you can get tiit to break loose and work again...if not you will have to take it out and replace the pump.
heatman101
SOURCE: Flush is weakening. Toilet paper won"t flush
Sorry to read about your problem, I hope this helps you out.
i dont think you have toilet issue,
Try this. take a large bucket, like a paint or home depot orange bucket. fill 1/2 way...
put some toilet paper in the toilet. Then pour the water in fast, and see how it flushes. it it does a easy flush then your drain is ok. if its slow, you have a drain issue and not the toilet.
if that the case, then goto the toilet, and clean out all of the little holes, that are around the unit.. where you see the water come out. they can be clogged up. a small type wire like a clothes hanger.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
