Question about Brother DCP-330C All-In-One InkJet Printer
Hi, i am from India and have a Brother DCP-165C Printer. Now i am facing problem with my Brother DCP-165C Printer. It is showing " Machine Error 46" What is this problem & how can i get a solution. Please guide me Regards
    Scholar:
    New Friend:
  • 34 Answers
Machine Error 46 indicates that the ink absorber pad is full and needs replacing. You will need an engineer to replace this.
If your machine is out of warranty, please contact Brother Customer Service:
7777 North Brother Blvd.
Bartlett, Tennessee 38133
1-877-BROTHER (877-276-8437)
901-379-1215 (fax)
M-F, 9:00am to 8:00pm Eastern Time
Posted on Jan 20, 2014
Anonymous
SOURCE:
Ray M.
  • 215 Answers
SOURCE: Brother printer dcp-330c error 46
press "menu" "black start" and "up arrow 4 times". that gets you into maint. mode to be able to reset purge counter. next enter code "80" by pressing up/down arrows and pressing "ok". press "black start" several times until you see "purge count". now press "2783" and "ok" to reset purge count. then press "black start" about three more times or until you see flushing count. again, press "2783" and "ok" to reset. now hit "stop/clear" a couple of times and press "99" to exit or use arrows to get to "99" . at this point, you may have to press "ok" to get out of maint. mode, but i think once you press 99 it backs out automatically. next time this comes up however, you will need to have your ink absorber box and flushing box replaced.
hth,
razors
Posted on Mar 30, 2009
n1wgk
Rick Johnson
  • 84 Answers
SOURCE: nozzle clogging on the Brother DCP-165C multifunction printer
take swabs and use alcohol to manually clean it...GENTLY and with not too much alcohol. You will go through several swabs. Use the foam swabs, not cotton, so you don't leave junk behind.
Posted on Mar 07, 2010
boyrevel
jonathan white
  • 71 Answers
SOURCE: Dear all here i am
Error 70 normally is a paper jam or something else that is stopping your print head moving correctly.
Open the covers, have a look, and after clearing the jam you must power off and on the machine.
- Dirty encoder strip
- Foreign object, such as a paper clip or ripped piece of paper is stuck in the machine
- Mechanical malfunction
The most common cause of this issue is dirt on the encoder strip.
Posted on Nov 01, 2010
mariolands
mariolands
  • 2296 Answers
SOURCE: Brother DCP-165C gives error print
The error message "Print Unable 46" is an indication that the machines ink absorbers are almost full. The ink absorbers hold liquid and dried ink after it has been purged from the print head. These absorbers can control enough ink for the expected life of the machine.
There is a possibility that this message may have occurred in error. Upgrading the firmware of the Brother machine may resolve the issue. Follow the procedure below to determine if a firmware update is required:
-if the display screen is displaying an error message, press the STOP/EXIT key to change the LCD to the main screen.
-press the # and * key at the same time. The first 2 characters on the top row will determine the ROM version.
If the ROM version is OE or greater (example: OF, OG, OH, etc), the firmware does NOT need to be upgraded. If the ROM version is OA, OB, OC or OD, follow the procedure on this link to upgrade the firmware.
If the message "Print Unable 46" continues to appear on the display the Brother machine after completing the firmware upgrade and your machine is within warranty (even if it's not under warranty you have to do the same thing), you have to take it to a Brother Authorized Service Center. http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/002600/000059/faq002659_000.html?reg=us&c=us&lang=en&prod=mfc290c_all&Cat=11
Posted on Jan 20, 2011
Nikolay Boychev
  • 525 Answers
SOURCE: clean unable 46 error on dcp 135c brother printer
the proper reset code sequence to reset DCP printers without numeric keypad should be as follows:
1. press buttons OK, Menu, Mono Start one by one, followed by up arrow key four times. this should all be done as short a time as possible, around 3 seconds.
2. enter maintenance mode 80 by pressing the up/down arrow key and set key to select numbers 8 and 0
3. press blue MONO start button to select PURGE which requires it to be pressed a number of times before PURGE appears on the LCD screen of the printer
4. then use the up'down key and OK button to enter the reset code 2, 7, 8 and 3 keys to reset the counter : Note this does not overwrite the number next to PURGE on the LCD screen but once the last number is added it gets reset to 0000
5. press Stop/Exit key to go to root of maintenance mode
6. enter 9,9 to exit maintenance mode
Posted on Jan 23, 2011
Dcp-165c clean unable trouble shooting and routine maintenance chapter in user's guide 46
for non fax models ie I have DCP 165C you say press ...... press up arrow four times then press 8 then 0 etc ... but I have no numbers to press!
Jul 15, 2012 | Brother DCP 165C Compact Color Inkjet...
Brother dcp 7055 error-EF
brother dcp 7055 error-EF laser
Nov 22, 2011 | Office Equipment & Supplies
PROBLEM IS MY PRINTER SHOW ERROR CLEAN UNABLE 46
Hi
This is the counter inside the printer which stops the printer unless it is reset. Follow the below steps to do the reset on your printer.
How to Reset Brother DCP 110C, 115C, 120C, 130C, 135C, 145C, 150C, 165C, 185C, DCP 195C Printer
May 25th, 2011 • Printer
How to Reset Brother DCP 110C, 115C, 120C, 130C, 135C, 145C, 150C, 165C, 185C, DCP 195C Printer:
1. Press the Menu, then Mono Start key then press the UP arrow key 4 times to make the machine enter the maintenance mode and "ERROR 46′ pops-up in the display.
2. Enter maintenance mode 80: Select 8 by pressing the UP/DOWN arrow key and push OK key and select 0 and push OK key
3. Now Press MONO arrow key several times until you see PURGE:XXXXX
4. Select 2 and push OK, Select 7 and push OK, 8 and push OK, select 3 and push OK and the purge counter is now reset to 00000.
5. Press STOP/EXIT key to go to root of maintenance mode
6. Enter code 99 to exit maintenance mode: Select 9 and push OK, Select 9 and push OK.
Jul 24, 2011 | Brother DCP-110C All-In-One InkJet Printer
I need a Brothers DCP-145C installer...A.S.A.P
sir, mam
my brother dcp-145c can create error no 46 how can i remove the error plz reply and gave me a solution how i can remove the error
My e-mail address is manishbhardwaj1993@gmail.com
Jan 17, 2011 | Brother DCP 165C Compact Color Inkjet...
Brother dcp-165c print unable 50
how ca n i fix my brother dcp 195 c unable 50?
Nov 21, 2010 | Brother DCP 165C Compact Color Inkjet...
Dear all here i am anil kumar from india i have MFC brother printer DCP-195C but i have facing problem when i print the page the printer show print unable error 70 please solve my problem thanks...
Oct 27, 2010 | Brother DCP 165C Compact Color Inkjet...
DCP-165C Compact Colour Inkjet Multifunction Printer: in brother dcp 165 printer the error message clean...
brother dcp-165c printer unable to clean , see troubleshooting and routine maintenance chapter in User's guide
May 16, 2010 | Brother DCP 165C Compact Color Inkjet...
Brother DCP-330C All-In-One InkJet Printer Logo
78 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Jim Keysor
