The ignitor module may have gone bad...this is a fairly common problem...Another thing you can do is to look at the ignitors where they come through..make sure that none of them is grounding out...this would cause no spark also....if you have the proper equipment, you can test the input voltage to the ignitor module to see if it has juice...if it does , then most likely the ignitor module...these are available from most appliance parts stores...or the manufacturer
Looks like you may have a bad ignitor. Try adjusting the arc gap. Sometimes of the ignitor is too close to the burner, the ignitor will not spark. It may also be that te burner is dirty and needs a little cleaning to allow for the electric ignitor spark to arc accross, thus producing ignition. Good luck.
This a coomon problem thaty occurs when you clean the "cooker". Residue from cleaning products may be preventing the ignitor from producing a spark (Arc) to the base of the burner. If you are able, clean the ignitor and adjust it. f you have too much space between the ignitor and the base of the burner, it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the ignitor. Good luck
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
The most common reason for this is debris that is gumming things up. Spray some degreaser on the ignitor and scrub it gently with a Q tip or a small brush. Repeat until it is all cleaned up and try again.
If cleaning it does not do it then you should check to be sure that the wired connected to the ignitor are nice and tight. if not, use pliers to snug the connectors down.
If all of these ideas are to no avail, replace the ignitor.
when you turn the knob or push a switch is going to the on posicion so that means that the switch is stuck in one of the knobs , you just have to see witch one is stuck
It is sparking because the module does not sense the heat which would normally cause the sparking to stop.
It can be caused by a poor ground, make sure the ignitor at that burner is clean and free from any obstructions. If it is then it could either be a defective ignitor or spark module.
