Error message : ink cartridge empty problem description: The error message is, "To print in color, install the following cartridges "Magenta". To print with black ink oly, click black only. The printer will replace colors with grayscale. To cancel pressthe cancel botton on the printer. If empty ink cartridge is not replaced soon, all printing will stop." troubleshooting : I replaced the cartridge and aligned the printer. The error message still pops up. setting changes : If I hit the "Black only" button, itprints normaly even in color.
SOURCE: Photosmart 7360 - replaced magenta cartridge. BUT
Deleted the printer and let Windows USB re-install it. Problem fixed.
SOURCE: Windows Ink Cartridge Empty false error message.
slowly off and on the printer for five times without cartridge, printer saves data of cart of last 5 only so next time it reads full ink..
Open the Dell 926's front cover with the power on and wait for the cartridge carriage to come to a stop. Remove the ink cartridges by pressing on the tabs at the top of each cartridge. Check the cartridges to make sure you have removed all of the blue protective plastic film. Look for the "Dell" logo stamped into the cartridges' lids to ensure they are genuine cartridges.
Clean the shiny metal portions of the ink cartridges with a damp microfiber cloth. Allow each cartridge to dry completely.
Clean out any paper, staples or other debris that you may be able to see, then reinsert the cartridges into their appropriate slots. Put the black ink cartridge into the left slot and the color cartridge into the right slot. Make sure both click back into place.
Close the Dell 926's front cover and turn off the printer. Unplug the power cord and USB cable from the printer for five seconds, then reconnect them.
If your Dell 926 fails to recognize the print cartridges after following the above instructions,
take it to a repair shop for servicing.
Good Luck and Happy Printing
