Both kids and I are upset. Tried the fuse and anything I could possibly try
SOURCE: Audiovox LCD FPE3206 problems
Hi, All.
I ordered a new power supply module on ebay. Cost about 106.00 delivered. Came in a few days. I replaced the unit, bunch of screws, all wires were cable plugins, no problems at all.
After reassembly, it worked. What can I say? Sometimes ya just get lucky.
tom
SOURCE: avd300 car dvd player is not working
I have one on eBay if you still need one.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=290281849245
SOURCE: Screen reads NO DISC
I had the same problem but I solved buying "Laser Lens Cleaner " Philips Magnavox after 3 attempts the DVD starts to work fine again. First only 3 min, then 10 min and now the entire CD cleaner and after I left the CD cleaner for 15 min I tried to play the DVD and WORKS!!! perfect!!!
SOURCE: no audio for mmdv2 O/H dvd player
Hello! If I understand you correctly, you have no audio at all; Both on radio and dvd player but video functions normally? Check fuse #14 (20A) located in the Integrated Power Module...It is located in the engine compartment...
Guru...........Saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
SOURCE: Audiovox ceiling mount with a 8 inch diagonal
Two ways to remove a stuck DVD are as follows, Open the vehicle's hood to locate the fuse box. Consult your owner's manual for help in finding which fuse controls the vehicle's stereo system. Remove the fuse from the box, and keep it out for about 10 minutes. Replace the fuse. The multi-disc changer will eject the stuck DVD upon reset. Straighten out a paper clip to create one long, thin piece of metal. Locate the small force-eject hole near the multi-disc changer slot. Push the end of the straightened paper clip into the force-eject hole. The disc changer tray will pop out, allowing you to remove the stuck DVD.
Force Eject
The reset described will also reset the system if it a resettable failure. If there was no disc in the player and it still won't function, then the unit may be bad and may need replaced. try the resets I described first and get back with me and we can go from there.
Thanks
I apologize. ..it is not the headrest...it is the factory system with the flip down screen located in the middle behind the sunroof.
