SOURCE: GMA 4082n device driver not working properly code 39
Since the optical drive is a plug and play device and root drivers are in the bios. I'm going to suggest a bios flash or update. Keep in mind that the bios are very important and you don't want to screw them up, so, download and save the flash before running. Never run a bios flash directly from the internet, the net is entirely to unstable, and a blink of the eye glitch can ruin your system.
http://support.microsoft.com/kb/314060
Try this article...............hope it should work otherwise would suggest something lese as well......All the best....TC
SOURCE: Not work
Try this...
http://support.microsoft.com/kb/929461/en-us
It should clear out error code 10
hope this helps...
The driver is actuall built in with the Operating system, there is no download for dvd rom drives.
But if you are can see an alert on device manager indicating drivers are not installed on your DVD ROM drive, just follow the steps here...
and it should work after several restarts, if you are running on XP.
Hi, the error code that you have is a known issue from Microsoft that needs a registry tweaks. Error code means "Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (code 39)". You can click on this link for your reference http://support.microsoft.com/kb/929461/en-us
To resolve this problem, remove the affected filter drivers. To do this, follow these steps:1. Click Start, type regedit in the Start Search box, and then click regedit in the Programs list.
If you are prompted for an administrator password or confirmation, type your password, or click Continue.
2. Locate, and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Caution There can be many instances of the registry subkey that is mentioned in step 2. You must make sure that you are in the appropriate registry subkey before modifying the UpperFilters and the LowerFilters values. To verify that you are in the appropriate registry subkey, make sure that the Default data value is DVD/CD-ROM and the Class data value is CDROM.
3. In the right pane, right-click UpperFilters, and then click Delete.
4. Click Yes to confirm the removal of the UpperFilters registry entry.
5. In the right pane, right-click LowerFilters, and then click Delete.
6. Click Yes to confirm the removal of the LowerFilters registry entry.
7. Exit Registry Editor, and then restart the computer.
This will surely help you resolve your issue. Good Luck!!!
Thanks
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?cc=us&lc=en&dlc=en&softwareitem=pv-37908-1
Here is the download link for the driver
Instructions on page
