When you start the archos 605 WIFI(30gb) up the screen stays on the archos entertainment your way, then after a few minutes goes to a white screen with 107 error message and gives you the option to repair or formatt but does neither, just keeps going back to same screen. also unit isn't recognized by my computer, so have no way of putting in any downloads that could possibllly fix it?
SOURCE: free download plugins
Hi you normally have to purchase the web browser plugin (not free) Sorry if i have spoiled your day
SOURCE: Archos 605 WiFi stuck
Hey
I suffered the same problem as you, fortunately I fixed it after a lot of messing around.
First what you want to do is switch off the system completely. Once the power light is off, switch the system back on, once the LCD screen turns on, immediately press and hold down the YV/LCD screen for about 5 seconds, a white screen should appear.
You will have three options, click the second option, (i think it is repair) and connect the archos to the PC. This will allow you to transfer all your files to PC because you can access the harddrive.
Once you have taken all the files you want, turn the system off again. Then again, turn the system on, hold down the TV/LCD button for 5 seconds until the white screen appears. Choose the format option. This will take your archos back to factory settings. It took me a few goes to get it back to normal but once its done, you will be glad you put the effort in.
Now all there is to do is to take your files back across via cable and you should be done!
I hope that helped!
SOURCE: Web Browser Plug-in Archos 605
There is a seller on ebay (name is luhahaca) that says he is an Archos official Plug-ins reseller. Just search for 605 Plug-ins on ebay. He sells a four pack for only $38.00. I bought and installed them and they work great. Really makes the Archos functional - the way it should come out of the box. Actually, (sadly) the way it does seem to come out of the box - I was disappointed when I received my plug-ins download. All 4 plug-ins = 2kb. Web browser with widgets, extended movie and music capabilities and Real player mode. It seems to me that all of this is already in the Archos, they simply charge extra for a key to access it. It's a shame. Totally worth the price if you have an Archos, but really too bad they feel the need to force their hand into your pocket after you've just given them hundreds of dollars. I think the unit would be reviewed better, and Archos wouldn't look so petty, if these features were just enabled right out of the box. (my opinion anyways)
Anyhow, I hope that answered your question!
SOURCE: getting a white screen with 102 error message
I fixed my son's 605 4 GB had Recovery code (104) on it. This might work for other error codes too. These are the steps i followed
* Use the computer for this process that you always used for this archos Archos should be plugged in toPc before starting the process.
* Download the firware Upgrade 2.1
* Plug the Archos to Pc
* When the white option screen comes up pick the format disk
* Wait until all done do not pick any option on archos after format is done Pc should recognize your archos in 5 seconds
* Put the firmware in root section of the archos not in any folder.
* Safely remove the usb for Archos from your pc first and then unplug the cable.
* Do not pick any option on the Archos screen
* Just turn it off from the power button by holding it until it turns off
* Wait about 5 minutes and plug it back to pc
* it will come up with white screen again but this time it will start Update you will see the progress bar moving, wait until it is all done, it will shut off. Turn it back on and your archos will be back to normal
