Have it repaired, no way around the problem for this otherwise. This is the place we recommend for the Canon Powershots: www.CamerasAndParts.com They are the best for repairing the Canons.
Your camera has an electronic view finder. To switch between the view finder and the display, you have to press the DISP. button several times and look what happens in Shooting mode and what in Playback mode. If only the display will come on, and the viewfinder stays black the camera will have a defect. If you can't use the camera anymore, because you only can shoot with the viewfinder, consider buying a new camera, because any repair will be more expensive than a new camera with the same quality.
SOURCE: I have a canon powershot sx20..looking through the
Your camera is equipped with a optical diopter that will allow you to adjust the optics in the viewfinder to your eye. meaning bringing everything into focus as it should. The way I use this (set it) is to let the camera auto focus on a subject and then turn the diopter until I see the subject clearly.
It really helps if the subject is about 12 feet away (get it real sharp) and the camera is mounted on a tripod. Once set I put a little dot of paper white out on the diopter adjustment knob so if it gets turned I know and can quickly return it to the correct spot. I'm including a diagram where this adjustment knob is on your camera, have fun.
Diagram
SOURCE: powershot s3 is
clean off all fo your contacts on the inside and the battery door, even try puling up on the connectors so that they get a good connection
SOURCE: I have a canon s3 15 turn the camera on the view finder blank
I would imagine a part has broken in your camera. The best advice I can say is to get it professionally serviced and don't take it apart on your own. Many times with these products when you take them apart, more damage can be done and you'll often need parts anyway. If you go to this site: www.camerasandparts.com they just service the powershots exclusively and they are amazing for servicing these cameras. They don't charge much at all with there total service packages and your specific problem is on their site. It doesn't say what the cause is but to fix it and service the camera with shipping is $89. I can tell you from experience they are wonderful for service on these Canon cameras. Hopefully you can get it working nicely again since that is a really nice camera.
