Source indicates I am in the correct source HDMI however menu will only give me Computer options. The screen is completely pink and the powere will automatically switch off. There is no way I can get to the color adjustments in the menu and have no idea what the problem is with the power.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
https://electronicshelponline.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
SOURCE: Protron PLTV-32CM LCD no picture
This TV set is still under the warranty and it seems proton has no local service available to you. I know its to late to tell you this but anytime you purchase a set, ask first and see if there is a service local to you. Ok enough of that noise.. I would go back to the store where it was purchaced and ask them if they know of any local shops that handle the warranty repairs.. If you want to pay for the repair, and that will most likly be alot for a flat panel set, You will have to call back proton and ask about the shipping cost and whos responsible for that.
SOURCE: no sound with hdmi source
ours would'nt work either we unplug it and turned back on and it worked
SOURCE: HDMI connection
A downloadable copy of the manual for a Protron PLTV-4250 is available here.
I went through it to check up on your concern. It was mention in page 34.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Protron > PLTV-4250
SOURCE: POWER SUPPLY FOR SPECTRONIQ PLTV=3250 (PROTRON)
I had a power supply for my Protron 32 inch TV that was not working. I bought the one on ebay and it stopped working after only three weeks. Ultimately I found a guy who could fix my original power supply for a reasonable price. It's been working for a year now with no problems. I wish I would have tried him first!!!! If anyone is interested his email is [email protected].
